Author Topic: Finally have the new bars on the bike  (Read 1264 times)
Anarchy78
« on: April 26, 2010, 09:17:04 PM »
Finally have my new handle bars on, going to work on them some more tomorrow, I was wondering if they are set at the correct angle?
(last 3 pictures of the album are the new handlebars)
(Sorry if your bike is in there, I like the look, and used em as examples of what I want mine to look similar too when I am done.)
(Also Ignore the ugly blue bike behind it, its not mine.)
http://www.facebook.com/album.php?aid=19228&id=100000076089998&l=084bce3092
« Last Edit: April 26, 2010, 09:20:19 PM by Anarchy78 »
Offline fastbroshi
  • Puppet
Re: Finally have the new bars on the bike
« Reply #1 on: April 26, 2010, 09:21:31 PM »
You've got them on upside down.
Just call me Timmaaaaay!!!
Anarchy78
« Reply #2 on: April 26, 2010, 09:27:26 PM »
Thanks, I will fix it tomorrow, and hopefully get the hardware on em and post some more pictures.
Offline Old75_ratafe
  • CB750 Cave Spelunking
  • 1975 CB750K
« Reply #3 on: April 27, 2010, 01:35:12 AM »
+1
If your going clubmans I gotta ask, why drag pipes?
1975 CB750K
Project Back in Black
Anarchy78
« Reply #4 on: April 27, 2010, 08:32:06 AM »
+1
I bought it with em on, I have the original pipes, they just need to be cleaned up. I am going to pick something else completely up probably once I can afford it.
« Last Edit: April 27, 2010, 08:34:56 AM by Anarchy78 »
Anarchy78
« Reply #5 on: April 27, 2010, 12:33:40 PM »
Alright have the handlebars on correctly, and obviously the old cables are not going to work, way to long, I was wondering if anyone have used these cables with the Clubman?
http://www.gdlcycles.com/asp1/modetails.asp?ItemID=TR_06-2121
http://www.gdlcycles.com/asp1/modetails.asp?ItemID=TR_06-2155
I am still looking for the rest of the cables if anyone has a site with good prices.
Offline fastbroshi
  • Puppet
« Reply #6 on: April 27, 2010, 12:41:19 PM »
  I'm using my stock length throttle cables with clubmans, you just have to make sure and route them a bit differently.  That said, mine feel a little stiff, not sure if shortening them a bit would help.
  I ended up getting a clutch cable too.  This didn't fit the bracket on the end of the clutch arm so I had to dremel it a bit, but it fit okay after that.
« Last Edit: April 27, 2010, 02:50:54 PM by fastbroshi »
Offline swellguy
  • An electric cattle prod is a
  • Divorce is so expensive because it's worth it.
    • http://ksphotos.com
« Reply #7 on: April 27, 2010, 02:17:52 PM »
+1
He said the last three pictures were of his bars:
What's upside down about that?
This project started in confusion and will end in disarray.
http://forums.sohc4.net/index.php?topic=76471.msg852227#msg852227
Anarchy78
« Reply #8 on: April 27, 2010, 02:22:04 PM »
+1
Opps sorry, I just fixed em today and posted new pictures, that was last night that I had em wrong, the pictures are still up of it from then though. Now the problem is finding all the cables I need without spending a fortune on em :/
  • 1975 CB750K
« Reply #9 on: May 01, 2010, 12:24:16 AM »
+1
Two things.. One much better  :P  and two I could be wrong but I think 550 cables are a bit shorter and hookup the same... but don't quote me on that.
1975 CB750K
