Author Topic: How to replace the command wire of the starter solenoid????  (Read 2223 times)
Offline yellowbirdrs
« on: April 27, 2010, 11:16:51 AM »
I'm relocating the solenoid and need some extra inches of the command wire (starter to solenoid) but i don't want to add an extension. So is there anyway to replace the  wire without open the start motor?   ???
X/A
Summer 2011
cb544
Re: How to replace the command wire of the starter solenoid????
« Reply #1 on: April 27, 2010, 12:13:52 PM »
Of course not, unless you can laso it out of there through another dimension.
No worries- just strip it down. I know it looks like a lot, and it probably is in fact, but don't worry about it. If you need a longer wire, install a longer wire.
Got any pictures of your plans?
