Author Topic: exhaust clamp springs  (Read 745 times)
Offline wannabridin
  • Patience made me a
  • -Garrett
« on: April 27, 2010, 12:39:48 PM »
does anyone have any close up pics of how i could adapt some springs to my exhaust pipes?  i really like the look, and the functionality is nice too.  i was thinking of adding some stainless springs.  can i simply drill a hole in one of the cooling fins and call it a day??  thanks guys!!
Offline Hannibal Smith
  • 3rd Grade Dropout
Re: exhaust clamp springs
« Reply #1 on: April 27, 2010, 01:35:16 PM »
By cooling fins, I am assuming that you are talking about running springs from the head to exhaust flange junction/union at the head?
I have always seen/done a rigid fastener mount at the head, and any subsequent sleeved unions were "sprung". Unless I am horribly out of date, I do not recall anyone relying on springs to anchor the exhaust directly to the head, I would estimate that you would run a 100% chance of leakage.
Follow my build "P38 Racer" in Project section
Offline wannabridin
  • -Garrett
« Reply #2 on: April 27, 2010, 02:43:27 PM »
newer bikes use them as a way to keep connections fitted, and to keep the pipes fastened to the head.  like below, except with a spring from the head to the pipe
they also use the clamps to keep the pipes fixed to the head, but a combination helps.  plus i think it looks pretty neat!
Offline eurban
« Reply #3 on: April 27, 2010, 03:22:38 PM »
Did you see the pic of Rossi's motogp setup at the end of this thread?   http://forums.sohc4.net/index.php?topic=69430.0
Uses the springs to hold the header sections together but the pipes are bolted to the head . . .
