Author Topic: Honda Wiring Codes  (Read 851 times)
Offline swellguy
  • An electric cattle prod is a
  • Divorce is so expensive because it's worth it.
    • http://ksphotos.com
Honda Wiring Codes
« on: April 27, 2010, 01:45:50 PM »
I was opening up some of the main wiring loom on my 73 cb750 since there were years of dried electrical tape, gum and drudge all over it. At at a point right behind the coils I found a solid light blue wire clipped and taped off. I noticed two identical light blue wires running through the loom and wondered why anyone would cut the wire. I stripped a bit of insulation off for this photo:
I tracked its conductivity up to a three post connector that would lie in the headlight bucket:
From the wiring diagram I can only see one solid blue wire that runs to a four way connector which I see is tied into the right signal lights. The only other light blue wires reads as having a white tracer (also tied into the right signal but going to no connection). Does the white hood over the connector mean that's the tracer? And if so, why would they run the wire all the way back into the loom and just tape it off?
This project started in confusion and will end in disarray.
http://forums.sohc4.net/index.php?topic=76471.msg852227#msg852227
Offline OldSchool_IsCool
  • Really feeling like an
Re: Honda Wiring Codes
« Reply #1 on: April 27, 2010, 03:08:40 PM »
Here is a guide to color codes:
http://forums.sohc4.net/index.php?topic=1012.msg188242#msg188242
Are you sure your bike is a K3?  Looking at a K2 wiring diagram, the front turn lamps are single filament and the blue with white tracer wire isn't used.  Could it be that the wire harness is not original and from a later model with dual-filament lights up front?
Wiring diagrams:  http://www.oldmanhonda.com/MC/WiringDiagrams/MCwiring.php#class
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline swellguy
« Reply #2 on: April 27, 2010, 03:33:12 PM »
Hey thanks for the color guide chart. The bike itself is a K3 but there is no blue/white wire in the harness. The blue wire with a white junction cover that jut doesn't connect to anything does account for what they could be. As far as I can tell they are stock single filament blinkers. Plus, it may very well be a different harness. That said, the only thing that didn't work before I took the bike apart were the headlights and these wires have nothing to do them, so we'll see when things get hooked back up together. It's just strange though.
