Author Topic: Big Bore CB550 Engine Build  (Read 19861 times)
Offline FunJimmy
  • Who you calling
  • Vancouver
Re: Big Bore CB550 Engine Build
« Reply #50 on: June 22, 2010, 01:32:22 PM »
As paulages mentioned a CB650 primary chain tensioner is a nice addition. Once installed you can see how much slack there is even with a new chain.
How is the 650 cam tensioner different than the 550 unit?
« Last Edit: June 22, 2010, 01:50:13 PM by FunJimmy »
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #51 on: June 22, 2010, 01:41:26 PM »
How is the 650 cam tentsioner different than the 550 unit?
primary tensioner. the 550 doesn't have one.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #52 on: June 22, 2010, 01:51:26 PM »
Paulages
Silly me.  ;D
Thanks for the clarification.
FJ
Offline Tretnine
  • Prove it,
  • Figuring it out, one expletive at a time.
    • http://www.behindbarsmotorcycle.com/
« Reply #53 on: June 23, 2010, 04:57:06 AM »
Hey hannibal, can you give me pictures of your tensioner addition when you get to it? I picked one of those up and want to see how it's done.
2009 Kawasaki Concours, 1978 cb550k, 2006 BMW F650GS
Member of the AMA
Offline paulages
  • 1976 cb735
« Reply #54 on: June 23, 2010, 07:06:39 AM »
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline Tretnine
  • Prove it,
« Reply #55 on: June 23, 2010, 11:29:15 AM »
That makes sense... sort of. I'm having a hard time getting my head around what's happening there. It's all welded to the top half of the case then you need to run a deeper oil pan to make room.
Member of the AMA
Offline paulages
  • 1976 cb735
« Reply #56 on: June 23, 2010, 12:07:46 PM »
Bwaller sent me a drawing I copied to make mine, but once I understood the orientation of the piece, the drawing wasn't really necessary. The hole for the bolt you can see the copper washer on (doesn't need to be copper, it was just what I had handy) is drilled and tapped into the corner of the case casting. The other is drilled in from the side of the top case, and drilled/tapped in the little piece. These two hold the mount in place, and the tensioner is mounted to it. The bolt that goes through the outside of the case needs a copper washer of course.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline Syscrush
  • Sold. :(
« Reply #57 on: July 12, 2011, 10:21:28 AM »
Did this build ever go anywhere?
