Tank is looking GREAT on the inside now!!! I let the tank sit for 24 hours with about 50% water, 50% Phosphoric Acid and then flipped it upside down for another 24. Every spot of rust is gone!!! I rinsed the tank really well with hot water and then coated the inside with some oil to keep any rusting from occuring before it gets fuel in it. Follow these threads for a quick and easy method to renew your tank too!!!
http://forums.sohc4.net/index.php?topic=21464.0 Quote from: Terry in Australia on May 05, 2007, 06:14:25 am
Steel wool (or even scotchbrite pads) will scratch chrome, and it's a lot of hard work. Get some phosphoric acid and add water at 5 parts water to 1 part acid and dip the rims, fenders, grab rails, blinker stalks, exhaust pipes, handlebars, chain guards, seat bases etc etc in the solution for a few minutes then just pull it out and rinse with clean water, and you'll think it just rolled off the factory floor, no scrubbing or polishing required! Cheers, Terry.
http://forums.sohc4.net/index.php?topic=31053.0Quote from: eurban on February 22, 2008, 07:40:47 am
The Home Depot's here in MD are now carrying phosphoric acid in their paint stripping section. Product is called "Prep and Etch." It is a gentler, more forgiving product than muriatic acid that takes overnight to work but leaves a rust inhibiting coating on the metal.
http://forums.sohc4.net/index.php?topic=31970.0Quote from: Roach Carver on March 15, 2008, 04:45:57 pm
did this, this weekend. Watch out for flash rusting. I read up on this a while back and it seems that the best acid to use is phosphoric acid as it will remove the rust while leaving the metal in a state that is somewhat inhibitive to oxidatation/rusting. I have done some small parts in phosphoric acid and noted no flash rusting.
