Author Topic: Piston rings????  (Read 646 times)
co425
Piston rings????
« on: April 28, 2010, 09:17:41 PM »
Hey all is there a difference between 69 750 rings and 71 to 76 rings. I need set for my 69 but the fit shows for 71 to 76. Can't think of a reason for them to be different. Also anyone have a good site to get rings at a good price for all 4 pistons in standard size. Late
Re: Piston rings????
« Reply #1 on: April 29, 2010, 07:29:16 AM »
Accordibg to the very early parts book i have there were different part numbers for the CB750, CB750K1 and the K2-K4 same as pistons so i suspect the earlier years are different especially as the pistons superceed to the later number but the rings do not.
The early manual (1970) that i also have makes no mention of land width only ringe end and side clearance
co425
« Reply #2 on: April 29, 2010, 08:31:54 AM »
Cool thanks for the info. I guess I will have to hunt down 69/70 piston rings as I am running the stock pistons.
co425
« Reply #3 on: April 29, 2010, 12:34:19 PM »
Just looked up the parts fisch and it shows the old rings are superceded by the new ones so I am assuming the 71+ rings with the same part number will fit.
« Reply #4 on: April 29, 2010, 12:46:47 PM »
Use your engine serial number to help. Provided the pistons have not been changed that should make it work. Then you'll know the superceded part will work.
co425
« Reply #5 on: April 29, 2010, 04:15:57 PM »
Original pistons. So I should be good. Ordered them from z1 for 13 and change a set. Should do the trick. Thanks for the help.
