Author Topic: brake rotors and caliper clearance  (Read 1884 times)
Offline hymodyne
« on: April 25, 2005, 07:59:06 PM »
evening all,
I've just received my front wheel and rotor for my '72 500 four. I've been scavenging off a '76 550, including the caliper. when I tried to settle the axle on the yokes, there's a gap of about 2mm, because the rotor is too big, and bottoms out on the caliper. switch rotors, switch calipers, what to do?
hymodyne
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
Re: brake rotors and caliper clearance
« Reply #1 on: April 26, 2005, 01:46:10 AM »
Sounds like the rotor (disk) is larger on the 550. Measure the diameter.
If so, I guess you'll have to switch rotors.
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
