Author Topic: How to remove bottom steering race from CB350f  (Read 5836 times)
Offline squire7986
« on: April 30, 2010, 04:28:03 AM »
This forum is a great resource for researching how to remove difficult parts from a 36 year old bike. There are plenty of posts on how to remove stubborn steering races to replace them with tapered bearings. I tried the cutting with a Dremel method and split it with a flat screw driver method. Also the pound it out with a chunk of broom handle method. http://forums.sohc4.net/index.php?topic=48295.0
I wanted to share with you all what worked for me, I'm calling it "knock it out with the old shock" method:
First, use the old 33mm front shock, I'm replacing the stock cb350f front setup with one from a 76 cb550 (35mm shocks - to big for this method).
Second, shoot some PB Blaster down the neck at the race and at the race directly. Just so it slides easily and minimizes any damage to the interior of the neck.
Third, gently insert the top of the old shock into the top of the steering neck until it stops at the top of the race, you might want to lightly grease the top of the shock that goes into the neck.
Fourth, stabilize the frame, grab the end of the shock and knock the top of the shock against the race.  If you are holding it right, it acts just like a impact wrench since the shock absorbs the recoil into your arms. ;D
Bingo! your race should fly out after a couple of good knocks.
You'll noticed the race is almost out - I had to take pictures when I noticed this was working so I could post it here!
1974 CB350f - Cafe Racer
Offline Cvillechopper
  • Is just pretending to be an
  • If not for my failures I'd never know my limits
Re: How to remove bottom steering race from CB350f
« Reply #1 on: May 04, 2010, 03:55:58 AM »
I like it.  Good job creating a better mouse trap.  In several months I'll be replacing the bearings on my 350 and will be using this method first.  Looks like much less work than some of the other approaches...
It is the mark of an educated mind to be able to entertain a thought without accepting it.  Aristotle
Offline leogriss
« Reply #2 on: May 04, 2010, 09:52:44 PM »
Just about time!
Was having trouble removing that steering race.
I tried flat head screw driver method and also tried to hit it with a brass rod but no luck.
I was trying to heat it up now but I guess I should try this first.
Any chance that I'm going to actually damage the fork tube?
Will definately give it a shot
Thank you
