Author Topic: kawasaki z650 piston  (Read 7965 times)
Offline bill hughes
« on: May 01, 2010, 04:35:54 AM »
hi im just into building a track day bike a 77 cb 750 and want tofit kawasaki z650 pistons does any one know will there be any isues with
piston / valve im using a webb 41 cam
regards bill hughes
Offline livefast_dieold
Re: kawasaki z650 piston
« Reply #1 on: May 01, 2010, 11:13:37 AM »
regards bill hughes
hi. I'm using the same pistons on my sohc for endurance races. No problem at all, valve clearance is about 2 mm (i'm using the same camshaft), compression ratio is 11.5:1 and displacement 760 cc. and they're 10 grams each lighter than stock pistons
Offline bucky katt
  • i am a pastafarian!
    • facebook
« Reply #2 on: May 02, 2010, 06:22:03 PM »
is there ANY machining at all that needs to be done? pin diameter the same? anything have to be taken off of the skirts?
Mark Twain - Notebook, 1894
« Reply #3 on: May 03, 2010, 01:10:59 AM »
none at all. Same pin diameter, some height of the pistons:
Offline KRONUS0100
  • MAD MATT THE MANIAC
« Reply #4 on: May 08, 2010, 07:25:50 AM »
wait...what?  z650...as in KZ650?     what year?  i jus let a 75 model go to the scrappers yesterday.....arrrgg!!!
MATT
Offline bucky katt
    • facebook
« Reply #5 on: May 08, 2010, 07:42:11 PM »
hmmmmmmmmmmmmmmmmmmmmmmm
« Reply #6 on: May 10, 2010, 01:14:44 AM »
kz650, i don't know year and model. It's the 2 valves for piston they made in the late '70.
BUT, be careful when installing the camshafts, I didn't double checked the distance between piston and valve after a tiny modification of the camshaft degreeing and the exaust valve hit the piston in all four cilinder after I missed a gear!  :-[ :-[
« Reply #7 on: May 10, 2010, 02:15:18 AM »
That's good info, I bought a KZ650 big bore kit (65mm pistons, takes a KZ650 to 720cc) years ago, I used the rings on my 836cc engine, but the pistons are sitting in a box still, they might be better off in an F2 though, as the crowns sit a fair bit higher? With these, I reckon the compression ratio in a "K" engine would be closer to 15:1! :o ;D
TCSOHCB750CAFE
« Reply #8 on: June 02, 2010, 05:21:38 PM »
Any gains/issues from doing this piston swap on a CB750K with stock SOHC?
I've got a LOT of KZ650 engines in my garage, and just came across this thread and thought "well, hey... that kinda rules!"
Offline Hasenkopf
  • Really, I'm not an
  • This space for hire.
« Reply #9 on: June 02, 2010, 06:24:01 PM »
that's funny... had i known that, I would'nt have got new rings for  my stockers !! :o :- :'(
I like berries.
Offline 75cb550 (kyle)
  • so you're calling me a
  • KEEP YOUR BOOGER HOOK OFF THE BANG SWITCH
    • My Album
« Reply #10 on: June 03, 2010, 02:15:18 PM »
higher compression..
TCSOHCB750CAFE
« Reply #11 on: June 03, 2010, 04:45:41 PM »
I gathered that... I should have been more clear. Any clearance issues with stock cam?
« Reply #12 on: June 03, 2010, 05:11:26 PM »
Send forum member "Soos" a PM, he knows everything there is to know about these piston conversions and if i am correct, he has just done up a set of Kawasaki 650 pistons for another member....
http://forums.sohc4.net/index.php?topic=63523.50
Read reply 55 and on..
Soos modifies a range of pistons for these bikes.
Offline bill hughes
« Reply #13 on: July 22, 2010, 09:48:15 AM »
hi i have now fitted kawasaki pistons to my 750 they fit ok just had to have the cylinders bored im running a web cam no problems with valve to piston have put in 125 main jets 4 into 1 ex at the moment it still on the bench but have run it at 6000 rpm and no problems ps how do i send pictures do i have to down size them
Offline kos
    • m3racing.com
« Reply #14 on: July 22, 2010, 10:47:57 AM »
Just for information. What is bore size of these pistons?
KOS
220...221, whatever it takes.
Offline turboguzzi
« Reply #15 on: July 22, 2010, 11:12:43 AM »
regards bill hughes
"using the same pistons on my sohc for endurance races"?
didnt see you in adria.... ;)
TG
Offline kos
    • m3racing.com
« Reply #16 on: July 22, 2010, 12:45:37 PM »
regards bill hughes
What is bore size in mm's?
KOS
TG
TCSOHCB750CAFE
« Reply #17 on: July 24, 2010, 09:42:21 PM »
KOS
62mm IIRC
« Reply #18 on: July 29, 2010, 02:05:34 AM »
regards bill hughes
TG
I had to decline that race. The bike didn't need a lot of work, but the real life (aka: work and engineer state abilitation) destroy my free time. We will be in Rijeka however!
The pistons need some more valve clearance, they didn't like high revs; especially if you miss a gear.
