Author Topic: Fuel petcock rebuild???  (Read 2257 times)
Buffo
« on: May 02, 2010, 04:47:56 PM »
hey guys... i just got a 1981 CB900f SuperSport and it has a leaky petcock... it is rivited shut... and i was wondering if anyone has ever drilled them out and rebuilt one of these?
And no... it is not leaking from the threads or the tank... it is leaking from the around the valve.
i tried to post this ? on cb900f.com but i kept getting an error message...
thanks
don
Buffo
Re: Fuel petcock rebuild???
« Reply #1 on: May 03, 2010, 06:17:44 AM »
i drilled it out... they are not rivits... they are posts that have been piened (?) over. the gasket is a round piece with 4 holes in it...
Buffo
« Reply #2 on: May 03, 2010, 06:49:20 AM »
i found a prt number for a "similer" honda part... i just dont know if it will work... 16953-283-000. and of course no-one has one in stock so i can compare.  :-\
Offline mgbgt89
« Reply #3 on: May 03, 2010, 07:17:26 PM »
Good luck. They are NLA i think, and nobody makes a rebuild kit for those. I ended up getting a used one that worked. I think some have had luck adapting a universal petcock on those bikes.
Buffo
« Reply #4 on: May 04, 2010, 11:40:16 AM »
i think that have found a part that will work... i will post my results in a couple of days when i get it
Buffo
« Reply #5 on: May 11, 2010, 12:41:31 PM »
works perfect... found the part... it is still used in boats... yeah me!
Offline kirkn
« Reply #6 on: May 11, 2010, 01:25:28 PM »
Well.....??
Details!  It don't do me no good just to know you figgerd somethin' out!
What part worked?  Where did you get it?  How much was it?  How much modification was required?  Because I'm sure there are lots of applications for it.
Offline 78whiteorbs
« Reply #7 on: May 17, 2010, 09:28:41 PM »
I second that,share your secrets
Offline Kframe
  • Life is good!
« Reply #8 on: May 17, 2010, 10:33:15 PM »
Does it look like this?
I got mine from Service Honda, but Cycle Recycle has them, too.
-K
2007 Triumph Bonneville T100, ARK'd, Pods, TOR's, Napoleon's, Innovate G5 Air/Fuel Gauge, Ignition Relocation by D9, Stebel Nautilus, Avon Roadriders
1984 Honda Shadow VT700c, Stock
1974 Honda CB550K, In rehab
1986 Honda Helix
