Author Topic: simple wiring diagram help  (Read 6584 times)
Offline 73hutch
« on: May 03, 2010, 02:12:48 PM »
working a bare-bones wiring harness for a 550 project. all i have to go by is the one i've posted here. does anyone have a better one to go by? the part that i hung up on is the middle part that looks like a peace sign. what is the "acc." and the "batt"?
78-550k
72-cb100
63 c100
75 xl350
84 gl1200
Offline jessezm
  • '77 cb400f cafe build
  • Always wrenching...
Re: simple wiring diagram help
« Reply #1 on: May 03, 2010, 02:36:40 PM »
Acc. is Accessories and Batt is to the battery (through the ignition switch).  this one's actually pretty good...
Offline SohRon
« Reply #2 on: May 03, 2010, 06:20:51 PM »
Try this link for a better schematic:
http://data.sohc4.net/CB550.jpg
These guys (who drew your schematic) shoulda' stuck with the VWs... Take a look at my build for some pics covering installing the harness that might be of some help.
« Last Edit: May 03, 2010, 06:29:19 PM by SohRon »
Offline smack
« Reply #3 on: May 03, 2010, 07:09:21 PM »
I just emailed you a better one.
imsam817
« Reply #4 on: May 03, 2010, 09:42:29 PM »
any chance you can email me the diagram also?  i'm currently working on my 550, and i'm having a problem figuring out a couple of wires... thanks
Offline Lars
« Reply #5 on: May 03, 2010, 11:56:33 PM »
Here you have a very helpful interactive diagram. Take the black dots in the table and put them in the other column, and you isolate your problem wiring. It is from "Oldmanhonda".
http://oldmanhonda.com/MC/wiring500.html
Lars
...if you got the ability to act...
Offline HawaiiMike
    • Hawaii realtor
« Reply #6 on: May 04, 2010, 11:05:09 AM »
Actually the Peace sign without the middle leg was the Love sign way back when.
imsam817
« Reply #7 on: May 04, 2010, 11:11:08 AM »
how different is the wiring between the 500 and 550's ?
Offline wannabridin
  • Patience made me a
  • -Garrett
« Reply #8 on: May 04, 2010, 11:41:40 AM »
he asked for a simple diagram, so the stock diagram isn't "simple" compared to the bare bones chopper ones.  i used that chopper one posted along with two very similar to these, and it yielded good results.  if you want turn sigs, you'll need to incorporate that part of the stock diagram into your build, as i don't know of a simpler way...  make sure you have GOOD GROUNDS and adequate and quality wire, and you'll avoid a lot of problems.  also, relay your headlight for sure, and horn if you want.  makes it brights and last longer and your horn will be louder w/ constant pitch.
the "peace sign" in the center is just your key switch.  it takes a constant hot to it, so it'll allow power to flow to the lights and horn, and then it allows it to flow to the starter as well on another pole.  make sure you also have a good fuse box, i'm going to use modern blade styles that have the little lights on them to show you if they're blown.
« Last Edit: May 04, 2010, 11:43:26 AM by wannabridin »
Offline jessezm
« Reply #9 on: May 04, 2010, 11:43:59 AM »
This is also a good site for understanding and building your wiring loom:  http://www.btinternet.com/~jhpart/bkwirec.htm
Offline wannabridin
  • -Garrett
« Reply #10 on: May 04, 2010, 11:50:37 AM »
great link there!!!  nice information!
Offline jessezm
« Reply #11 on: May 04, 2010, 11:55:18 AM »
Yeah if you have the patience to sort through the stuff that doesn't apply is totally worth a careful read.  I'm about to delve into the wiring for my project as well, so I've been looking pretty closely at all this stuff!
Offline Feyden
  • CB550 F1 (Kickass!)
  • One Step at a Time....
« Reply #12 on: May 04, 2010, 12:38:44 PM »
While I was bored at work, I did some looking up on custom wiring projects... these require some small modding in one place or another, but you'll see it..... check out these links... very helpful stuff.
http://www.torkypig.com/tp/wp-content/uploads/mutantwiringjpg.jpg
http://www.ripper1.com/tech/wiring.php
*click on first pic here.
Here's the images *I'll show the first link first, it's my fav.
And, the second
Thought these may be able to help someone out
Offline wannabridin
  • -Garrett
« Reply #13 on: May 04, 2010, 01:22:56 PM »
very nice finds!!  i like that 1st one a lot, and the 2nd is good for turn sigs!!  you don't need a 4 position ignition switch though.  also, don't forget if you want to run a starter switch, then that needs to be on the red starter wire.  alternatively, you could run a relay for your starter to avoid passing all that current through just a switch.  at least i think you could, this seems safer, no?
oh wait, the 2nd drawing takes this into consideration.  i like the 2nd one better now :D
Offline Feyden
« Reply #14 on: May 05, 2010, 06:02:07 AM »
Yes, Also, for additional info, it is to my understanding that these diagrams were intended for Harley's originally... But, I see no reason why you couldn't make them work, I intend to try it out... I can get all the stuff I need for the first one at Radio Shack for $31.... Also, keep in mind that the "COIL" is rigged for 2 spark plugs... NOT 4!
Oh, one more thing, you can view an interactive diagram here... HUGE HELP if you can manage a computer in the shop!!!!!!!!!!!!!!! PURE GENIUS!!!!!
http://oldmanhonda.com/MC/wiring.html
« Last Edit: May 05, 2010, 06:11:11 AM by Feyden »
Offline mknbklyn
« Reply #15 on: November 28, 2011, 07:17:44 PM »
Hey there,
Any of you guys on this thread pull one of these wiring diagrams off? I really want to yank the guts out of my 78 550k and start over very clean and simple with as many modern electrical parts as possible. I'm a little weary at this point even with the diagrams though.
