Author Topic: Dyna S Installation Instructions  (Read 1043 times)
Offline yellowbirdrs
« on: May 04, 2010, 10:28:26 AM »
My old Dyna S have different wire colors  ??? the print instructions show red, yellow & blue wires but I have red, withe & black  ??? ??? Can some one help me on this one.
The Dyna S was installed on the bike before the over-hulling but I skip the photo set up step because I was confident I had the insurrections  ::)
Wrong forum please remove this post.
« Last Edit: May 04, 2010, 10:30:30 AM by yellowbirdrs »
X/A
Summer 2011
Offline Triffecpa
Re: Dyna S Installation Instructions
« Reply #1 on: May 04, 2010, 01:12:44 PM »
the latest Dyna units that I have seen have the white/black/red wires.  However, they have a little collar that slips over the black and white wires that are either yellow or blue.  Can't honestly remember which is which.  However, if you hook the red to power and the white and black to the coils, you will either be correct or you will be 180 degrees out.  So hook your wires up and then hook a plug to the no. 4 plug wire.  Turn the ignition on and slowly turn the crank by hand until the plug fires (ground the plug against the motor).  Then you can look at the timing advance plate and see if you are at the 1-4 F mark or at the 2-3 F mark.  Obviously if you are at the 1-4 mark you have the wires hooked up correctly.  If you are at the 2-3 mark, then swap the white and black wires to the opposite coils and you should be right on.
Tracy
