SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
Using A Motion Pro Carb Tuner
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Using A Motion Pro Carb Tuner (Read 899 times)
campbmic
Sea-Foam and Flaming 151 is a dam good
Hot Shot
on:
May 05, 2010, 09:42:38 am »
Hey guys I have a mercury filled old school motion pro carb tuner and had a question about synching my carbs up. After I hook up the carbs when should I adjust the air/fuel mixture screw as opposed to changing the slide height screw and nut? Is the air/fuel mixture screw like a fine tuner or should they all just be 1 1/2 turns out?
Thanks for the help!
-Michael
Logged
Its hard to be wrong when you know nothing!
Duke McDukiedook
Space Force 6 Star General
Really Old Timer ...
Wish? Did somebody say wish?
Re: Using A Motion Pro Carb Tuner
Reply #1 on:
May 05, 2010, 09:45:56 am »
Should be just the 1.5 turns out if everything is stock.
Logged
"Well, Mr. Carpetbagger. We got somethin' in this territory called the Missouri boat ride." Josey Wales
Inigo Montoya
Master
Reply #2 on:
May 05, 2010, 10:04:22 am »
Camp, I have wondered this many times but the best I can come up with would be a good bench sync followed by a the final sync, then tune the idle mix with an electronic tach. I don't trust the "ear" method as it is inaccurate at best.
Logged
campbmic
Hot Shot
Reply #3 on:
May 05, 2010, 10:49:54 am »
By the way I should have mentioned Im running a MAC 4-1 and EMGO pods
Logged
Duke McDukiedook
Reply #4 on:
May 05, 2010, 12:04:01 pm »
Then all bets are off, you get to fiddle with jets, needle positions and air screws, aren't you the lucky ducky??
You fiddle with the air screws with an accurate tachometer after you dial in the jetting/needle setting, bench and manometer synch.
Last Edit: May 05, 2010, 12:05:43 pm by Dukiedook
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
