Author Topic: Neutral light not working on 78 CB750  (Read 4325 times)
Offline Turbogrimace
    • Draft Cycle Works
« on: May 05, 2010, 09:58:42 AM »
It's got a good ground, but it wont light up when it's in neutral.  Could the sensor be bad?  Can it be replaced?
Offline domer
Re: Neutral light not working on 78 CB750
« Reply #1 on: May 05, 2010, 10:04:45 AM »
stupid q, but did you check the bulb?
    • Draft Cycle Works
« Reply #2 on: May 05, 2010, 10:27:29 AM »
LED is bien.
Offline scondon
  • Mmmm......tasty bugs
« Reply #3 on: May 05, 2010, 11:16:04 AM »
The neutral switch is easy to replace. 10mm wrench to remove the retaining bolt, and it should pull right out.
 There is a wire attached to the top of the switch. Try disconnecting this wire and see if your neutral light comes on. I forget how this switch works, but I think that when it's grounded your light goes off. Basically, just confirm that your neutral light does indeed work before going through the hassle and expense of replacing the switch. Could just be a wire unplugged somewhere.
« Reply #4 on: May 05, 2010, 06:20:07 PM »
When the bike is in neutral, the switch grounds, and when in gear, the switch is open. If you connect the light green/red wire that connects to the switch to ground, the light should come on. If it doesn't, the switch is not the problem.
Offline cookindaddy
  • I sure love this bike!
« Reply #5 on: May 05, 2010, 06:27:12 PM »
Did you say that you are using an LED? Is the polarity correct? LEDs only work with current flow in one direction.
George with a black 78 CB750K (in Lion's Head, Ontario, Canada)
    • Draft Cycle Works
« Reply #6 on: May 06, 2010, 11:36:19 AM »
The harness only allows me to put it on one way.  I'll check out out though.
Offline JLeather
« Reply #7 on: May 06, 2010, 11:50:02 AM »
So you've picked a year for that bike then?   ;D
    • Draft Cycle Works
« Reply #8 on: May 06, 2010, 12:29:38 PM »
no haha.  It's a 72 with a 78 engine.  Title says 72 and so do I.  ;)
