Author Topic: What's up with my center stand?  (Read 1268 times)
Offline Scott S
« on: May 06, 2010, 02:28:58 PM »
  Can I get some pics/measurements of the CB500 centerstand?
 I recently got one for my '71 CB500 and it's too short and too narrow. It won't pick the rear wheel up off the ground when the bike is up on it. When the bike is down, the legs hit the chain and brake rod.
 What is the width between the feet (on the onside)? If the bike was up on the stand, what would be the measurement from the pin/shaft to the foot (or ground)? I think I have one from the wrong model....
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Scott S
Re: What's up with my center stand?
« Reply #1 on: May 06, 2010, 02:50:55 PM »
 I got measurements from a forum member and it seems I have the correct stand.
 I do not have the stock exhaust. Do I need to fabricate a stop to keep it from coming up and hitting the chain/rod?
 But that doesn't address the issue of not lifting the bike completely. Is the rear wheel supposed to clear the ground when the bike's on the center stand?
'71 CB500 K0
'81 Yamaha XS650
Offline kck3
« Reply #2 on: May 06, 2010, 03:19:22 PM »
The rear tire could have been replaced with one that is not recommended for the bike-the tire may be too tall resulting in not allowing the stand to raise the rear.
Offline Scott S
« Reply #3 on: May 06, 2010, 03:52:24 PM »
 The tire is a 110-90-18, the modern equivalent of the 3.50-18.
'71 CB500 K0
'81 Yamaha XS650
Offline Nikkisixx
« Reply #4 on: May 06, 2010, 04:50:29 PM »
So you got that part figured out.  Does the bike rest on the rear tire with the front off the ground?
Offline Scott S
« Reply #5 on: May 06, 2010, 05:25:05 PM »
 No, both wheels are on the ground when it's on the center stand. I have to put a block of wood under the stand to get the rear wheel off the ground.
'71 CB500 K0
'81 Yamaha XS650
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #6 on: May 06, 2010, 05:29:19 PM »
So it's on a 4-point stance when on center stand?  If you park on hot asphalt, that could be a GOOD thing!
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline Scott S
« Reply #7 on: May 07, 2010, 03:46:50 AM »
 Are you able to run the center stand with a Mac 4-1? I tried mounting the L shaped bracket that came with it on the left passenger peg but that doesn't touch the center stand. It looks like it's supposed to mount on the right passenger peg along with the muffler hanger, but it touches the muffler.
 I can live with putting a block of wood under the stand to get the bike off the ground. The only time I REALLY need the rear wheel free is for chain adjustments.
'71 CB500 K0
'81 Yamaha XS650
Swoop
« Reply #8 on: May 07, 2010, 01:39:49 PM »
Sometimes the mounting points or cross member get stressed from people sitting on them while on the stand. Causes this issue. It can be addressed with small shims in the right place.
Steve
Offline tlbranth
« Reply #9 on: May 08, 2010, 09:52:31 AM »
This is a stretch but waaaay back in the 70's I put a 16" harley rim on my 750 necessitating shortening the center stand. Might you have a shortened stand?
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
