Author Topic: 1975 CB750F Cinder Cone  (Read 20890 times)
Offline CBcafeJunkie
  • 75 CB750F
Re: 1975 CB750F Cinder Cone
« Reply #75 on: November 26, 2013, 06:24:09 PM »
You could build another 750 that's beyond repair and save this one incase it ever wants to go back to stock
Very good thought! I will be watching out for a roller without motor. I will need the carbs though. However I really like the brat, cafe, and bobber builds. Sooooooo.... I don't think I'll be one to return it to stock. :)
  • 75 CB750F
« Reply #76 on: November 26, 2013, 06:26:58 PM »
In for the follow. Beautiful build!
Thanks!!! It's been a long time on the works. It's nice to have other fine builders admonish my work. :)
  • 75 CB750F
« Reply #77 on: November 26, 2013, 08:46:54 PM »
Alright here's some things I'm dealing with now and some pictures of me electrics box
It's pretty rough but it's also my first time doing metal bending and sheet metal work. I bent it using my vise.Its made out of 22 gauge steel and welded at the seams. I am going to paint it white in a few days.
This is my regulator I'm not sure if I wrecked it yet but time will tell hopefully not it's an old 1970's ford
And here is my 3 phase rectifier that I heat sinked to my electrics box
And this is the battery tender dongle :)
Ok so here are some issues I'm having with my wiring.
When I turn the bike on both turn signals act like running lights lol but when I turn the turn signal to the left the left one goes out and same when switched to the right
Next when I push start they both go out and the neutral light on my gauges lights up when I press start also
So that's all so far I'm just trying to get the electrics as clean as possible then make a seat pan and heavily debating on chopping the tail and rear support and welding in a hoop then painting.
  • 75 CB750F
« Reply #78 on: November 30, 2013, 08:32:27 AM »
Had a small disaster the other day my regulator was not functioning as need or was hooked up wrong and it burnt out a battery and turned my pan into a tray of fire. fortunately i was able to avert disaster and get everything saved but 1 wire. I then went back to stock reg and painted and reorganized my pan. I think it looks a ton neater
  • 75 CB750F
« Reply #79 on: December 02, 2013, 02:06:48 PM »
Still working on blinker issue hoping it's just my flasher  recent pick 70's style also brushed up my brake calipers
  • 75 CB750F
« Reply #80 on: December 14, 2013, 02:14:38 PM »
Got my replacement rear caliper in the mail today an found that the MC is bad :( Think i saw an after market that could work
