Author Topic: clunk clunk clunk.. Daimond master link Stretched!!!  (Read 3915 times)
Offline grumpy
  • ..... '73 750K3 .....
« on: May 07, 2010, 07:10:47 PM »
My K3 started making some nasty sounding rhythmic clunks.
hurah.
They correlate to the speed of travel (ie faster speed, faster clunks)
It's coming from somewhere in the drive train. It feels like a stiff link or a f'ed up sprocket tooth - but it isn't either. It's really noticeable if I put it in N and coast (motor running or not). I can feel it thru the frame & coming up thru the break pedal. I cannot feel it in thru the front brake.
I have:
taken the chain off & checked for stiff links
spun the R wheel and drive sprocket to check for wobbles, bent teeth, etc.
spun the R wheel while on the center stand to check for binding in the hub
taken the R wheel off & checked the hub & brake
so what's next, final drive shaft & tranny ?  >:( >:( >:( >:( >:( >:( >:( >:( >:( >:( >:( >:(
« Last Edit: May 09, 2010, 06:30:18 PM by grumpy »
Re: clunk clunk clunk..... damn, damn, damn!!!!!!!
« Reply #1 on: May 07, 2010, 07:37:44 PM »
Remove the chain and try running it in first or second gear again to see if you still have the problem through the gearbox. I had a single chain link go south once and it sounded familiar to your issue.
« Last Edit: May 08, 2010, 03:43:17 AM by bwaller »
Offline GammaFlat
« Reply #2 on: May 07, 2010, 07:48:49 PM »
I've heard spokes make a creak (but not really a clunk).  Recently I learned that a rear wheel with loose spokes has probably been used lots for burnouts.  Whatcha been doin'? :)
K6
K7
Suzuki GN400 - Ignition fixed!
03 KLR650 - Doesn't do anything very well but.. well.. does everything.
Offline IndyFour
« Reply #3 on: May 07, 2010, 08:28:48 PM »
My 550 did that last season....ended up being too much slack in the chain.  Tightened it up and it went away.  You probably already checked that, though if you had the chain off.
1974 CB550K
2000 VFR800FIY
__________________
Indianapolis, Indiana
Offline grumpy
« Reply #4 on: May 08, 2010, 08:07:33 AM »
It feels like a frozen link - that's what I thought it was until I checked the chain. I'll recheck, tho. If it's OK then I'll try rolling it w/out a chain to check the rear hub under load.
It's not spokes. I know what that sounds like. And definitely no burnouts for me  ;)
I'll try running the motor w/out a chain & report back.
Man I hope it's not in the tranny, like a blown bearing or something. I DO NOT have the money for a major fix this year....
Offline tlbranth
« Reply #5 on: May 08, 2010, 09:18:22 AM »
A stiff link would clunk with a much lower frequency than  a missing gear tooth or some such I would think. Can you run it on the center stand and give it a listen?
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline grumpy
Re: clunk clunk clunk.. Daimond master link Stretched!!!
« Reply #6 on: May 09, 2010, 06:32:05 PM »
Found the problem
The master link is pretty stretched out - causes the chain to mis-engage the cogs.
Damn, that chain (and cogs) has less than 10,000mi on it...
There goes at least $60  :(
« Last Edit: May 09, 2010, 06:41:02 PM by grumpy »
« Reply #7 on: May 09, 2010, 07:05:50 PM »
Do you mean the chain is stretched.. ???
 If you put that chain on badly worn sprocket, it would shorten the life considerably.
Offline grumpy
« Reply #8 on: May 09, 2010, 07:43:24 PM »
Nope - just the master is stretched.
The chain engages the cogs fine until the master comes around. The master is visibly longer than it should be. It causes the links behind it to want to ride up the "pushing" teeth & makes the chain tension go up til the master drops off the cog again.
« Reply #9 on: May 09, 2010, 07:50:32 PM »
It may not be the master has stretched, rather that the rollers on the end links of the chain are are damaged, or the tube they roll on that's pressed into the side plates, that the pins of the master go through.
« Reply #10 on: May 09, 2010, 07:53:10 PM »
Diamond also makes chain for industial use.. not nearly as strong as say an XDL Diamond  (real bike chain)
 I will bet the master GOT SWITCHED FOR A CHEAPO ONE, and pins are severly worn...
 just get a new master link.. from Diamond... for MC chain..
Offline mystic_1
  • 1970 CB750K
« Reply #11 on: May 09, 2010, 09:12:58 PM »
Guy I knew years ago (more than a bit of a dumbass) used an industrial chain master link from the hardware store on his bike once.  As I recall he found out REAL FAST how bad an idea that was.
Grumpy, you said the chain and sprockets have less than 10k miles on them, what about the master?  Did you re-use the old one or get a new one?
Also, post pics.  I've never seen such a failure in person and I'm curious.
mystic_1
- John Augustus Shedd
Offline grumpy
« Reply #12 on: May 09, 2010, 10:05:06 PM »
The master is the one that came w/ the chain.
I'll try to get pics tomorrow after work - too dark out there right now...
« Reply #13 on: May 09, 2010, 10:11:38 PM »
 Just get it on the rear 1/2 of rear sprocket, and pull it out, pins are probably 1/2 wore thru.
 If you got a piece of wire, put it thru the chainends will hold it if you dont roll the bike.
 I am sorta thinking it either came with a bad one, or someone pulled it out, them replaced it with a black diamond cheese version.. ;)... sideplate should be marked
« Reply #14 on: May 09, 2010, 11:01:24 PM »
About 2 years ago I bought a Diamond Powersport (their new name for the XDL) and the dealer sent me a Diamond industrial masterlink with it. They are very different! I called the dealer and told him: he had no idea they were any different for these 'superchains'. He sent me 2 in apology, and I gave one to a friend. (I love happy endings!)  :D
Offline grumpy
« Reply #15 on: May 10, 2010, 08:04:25 AM »
Anyone know where I can get a 530 XDL master w/out having to pay $10 S/H ?
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #16 on: May 10, 2010, 08:21:57 AM »
Was that a clip or rivet master they gave you?
Offline grumpy
« Reply #17 on: May 10, 2010, 08:37:01 AM »
« Reply #18 on: May 10, 2010, 09:11:55 AM »
I would recommend using a rivet master if you are going to use one.
Offline grumpy
« Reply #19 on: May 10, 2010, 07:23:09 PM »
...if you are going to use one.
Is there any way NOT to use a master?
Here's a pic. The master has been in & out twice now so the clip is tweaked (and dead). Yes, it looks like it's stiff but I assure you it pivots freely. It's being held out by the tooth behind it (to the left in the photo). The links following the master are hitting the teeth "late"...
« Reply #20 on: May 10, 2010, 07:31:35 PM »
 Roll it so the master is not on the sprocket.. now at about 2 or 3 oclock..position..pull chain outward from sprocket.. how far does it move?
 If you had the master out and the pins dont show massive wear, that is likely not the problem..
« Reply #21 on: May 10, 2010, 07:39:43 PM »
Offline grumpy
« Reply #22 on: May 10, 2010, 08:10:14 PM »
It barely pulls away - so I don't think it's total chain stretch.
I'll have to pull the master again & check it's rollers for wear. I didn't even think of that the first time it was out.
I have another chain on the way - I just hope the cogs are OK. I REALLY don't wan to replace those again after only a few thou miles.
« Reply #23 on: May 10, 2010, 08:17:36 PM »
Post a good picture of the sprocket with the chain off, side view, so we can see the shape of the teeth.
« Reply #24 on: May 11, 2010, 01:24:40 AM »
Endless chain, no master link but that would require removing the swingarm to remove the chain.
And buying a whole new chain.
« Last Edit: May 11, 2010, 08:52:45 PM by Dukiedook »
