Author Topic: cutting frame?  (Read 1996 times)
Offline Zig
cutting frame?
« on: May 07, 2010, 11:34:32 PM »
am thinking about removing rear footrest brackets from my 750 frame. have read here somewhere that after doing so a forum member had to "fill holes in frame" ?? dont get it, are those bracket tubes thru the frame and then welded?
or, another way to put it, is there a hole "punched or bored" in main frame before footrest brackets are inserted, aligned and then welded?
Offline mystic_1
  • 1970 CB750K
Re: cutting frame?
« Reply #1 on: May 08, 2010, 02:07:26 AM »
I'm pretty sure the rear footpeg brackets are just welded to the surface of the frame tubing.  You should be able to just cut them off and grind it smooth.
mystic_1
- John Augustus Shedd
Offline lordmember1969
Re: cutting frame?
« Reply #2 on: May 08, 2010, 02:36:58 AM »
Yes you can:) There are no holes there:)
1977 CB 750 SS Cafe
1977 CB 750 Basket case
1971 Mustang Grande
1928 Model A Pheathon Hot Rod
1977 Harley Custom FXE
http://forums.sohc4.net/index.php?topic=70333.0
Offline Zig
Re: cutting frame?
« Reply #3 on: May 08, 2010, 02:10:13 PM »
kool, thanks.
Offline ksmith0034
  • When I grow up I want to be a
    • Please subscribe to my motovlog
Re: cutting frame?
« Reply #4 on: May 08, 2010, 02:55:46 PM »
Mystic is right.  I cut the triangles off my K1 and ground it smooth.  There were no holes.
It took 10 years but she's finally done!
Stocker 2 Rocker CAFE conversion
My YouTube channel HERE:
https://www.youtube.com/MotoCafeRacer
