Author Topic: Norwegian cafe.. Oil tank in the swingarm....  (Read 98446 times)
Offline lordmember1969
Re: Norwegian cafe
« Reply #125 on: July 10, 2010, 04:02:08 PM »
That will work :) :)
1977 CB 750 SS Cafe
1977 CB 750 Basket case
1971 Mustang Grande
1928 Model A Pheathon Hot Rod
1977 Harley Custom FXE
http://forums.sohc4.net/index.php?topic=70333.0
Re: Norwegian cafe
« Reply #126 on: July 11, 2010, 02:03:44 AM »
Triumph?
Or Honda headlamp? :) :) ???
« Last Edit: July 11, 2010, 02:07:36 AM by lordmember1969 »
1977 CB 750 SS Cafe
1971 Mustang Grande
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=rl3hf3gn88qnjbqppm8e6t1nr1&/topic,60973.0.html
Re: Norwegian cafe
« Reply #127 on: July 11, 2010, 04:40:04 AM »
think honda looks to flat..and you have distens inof back to gov the english vay..
i faund an not running 750 74..for 8000 danish kroner..its almost orginal..and nothing serius vrong...is it for mutch..or can you get a theper in norvay..its kosts alvays atlast 20,000 to make a mc stabil and safe running..så it ends at ca 30,000 kr..then an import from usa are maybe theeper..just thinking laut,,,,
i hate all this v-w.... vords
Re: Norwegian cafe
« Reply #128 on: July 11, 2010, 11:29:17 AM »
8000 dkr is not bad, it depends on whats wrong with it, and the condition. If its ok, all the parts are there? I think it will bee hard to find it as cheap in Norway. Maybe for less in USA, but add the freight and taxes it will be more expensive than the one you found.. But it depends on the condition.. :)
1977 CB 750 SS Cafe
1971 Mustang Grande
Re: Norwegian cafe
« Reply #129 on: July 11, 2010, 01:45:02 PM »
Decided on the headlamp:)
Made new headlamp ears, with original f1 ears and some cheap universal ones:)
And yes I will clean up the headlamp:):)
1977 CB 750 SS Cafe
1971 Mustang Grande
Offline strynboen
Re: Norwegian cafe
« Reply #130 on: July 11, 2010, 02:02:45 PM »
alt.. ::) take some rs tubes..and put them over fork legs..vith some rubber rings as spacers..and veld these ears on and polish
its vill lokks as it sits right on..and there vill not be anything to skrev on,,just klean tubes..(.rustfri rør,,på dansk)
but maybe it vill make prob handle bar grips
there is alså the 400 four vay..hvere mountings are op and dovn on trippel mounts..
but its looks great that you are making
have you get that ide vith gas pump in a ekstra tank...sitting hvere oil tank are placed..great idea..evt make a dobbelt tank for oil/gas/pump..
« Last Edit: July 11, 2010, 02:14:00 PM by strynboen »
Re: Norwegian cafe
« Reply #131 on: July 11, 2010, 02:14:29 PM »
That would look a lot cleaner:) I might just steal that idea:):) For now I am more free to move it up or down. Till I decide exactly where i want it. But thank you for the tip:):)
1977 CB 750 SS Cafe
1971 Mustang Grande
Re: Norwegian cafe
« Reply #132 on: July 11, 2010, 04:12:46 PM »
What are rs tubes?
Re: Norwegian cafe
« Reply #133 on: July 12, 2010, 12:42:41 AM »
What are rs tubes?
Stainless steal tubes :)
1977 CB 750 SS Cafe
1971 Mustang Grande
Offline Zig
Re: Norwegian cafe
« Reply #134 on: July 12, 2010, 01:48:11 AM »
I like the tank,clipons and headlight. Nice look.
Re: Norwegian cafe
« Reply #135 on: July 12, 2010, 05:27:31 AM »
1977 CB 750 SS Cafe
1971 Mustang Grande
Offline HondaNorway
Re: Norwegian cafe
« Reply #136 on: July 28, 2010, 02:07:15 PM »
This thread really inspires me to build a café racer of a part's bike I have  ;D Great bike! Did the front rotor fit on the wheel without any modifications?
-Stian
'74 CB750
'76 CB750F
Re: Norwegian cafe
« Reply #137 on: August 02, 2010, 09:45:19 AM »
Hi Stian:) Thanks
Had to make a spacer to make the rotor fit the wheel. Used alloy and a lathe:) Ca 9mm thick.. Can take some close up pictures so you get an idea? :)
1977 CB 750 SS Cafe
1971 Mustang Grande
Offline HondaNorway
Re: Norwegian cafe
« Reply #138 on: August 02, 2010, 01:48:00 PM »
Hi Stian:) Thanks
That would be great!!
-Stian
'74 CB750
'76 CB750F
Re: Norwegian cafe
« Reply #139 on: August 14, 2010, 02:57:28 AM »
Hi Stian:) Thanks
-Stian
:D
Here you go, sorry it took so long...
1977 CB 750 SS Cafe
1971 Mustang Grande
Re: Norwegian cafe
« Reply #140 on: August 14, 2010, 03:18:36 AM »
Did the same on the back:)
Used cbr1000 rr caliper,rotor and footrest..
9$ rotor
15$ caliper
19$ footrest
Ebay:)
« Last Edit: August 14, 2010, 03:36:35 AM by lordmember1969 »
1977 CB 750 SS Cafe
1971 Mustang Grande
Offline HondaNorway
Re: Norwegian cafe
« Reply #141 on: August 14, 2010, 12:36:26 PM »
9$ rotor
15$ caliper
19$ footrest
Ebay:)
Thanks for the pictures! I guess I have to spend some hours on Ebay looking for parts now  :D
'74 CB750
'76 CB750F
Re: Norwegian cafe
« Reply #142 on: September 22, 2010, 08:21:05 AM »
Anyone found a god bicycle speedo? Want one with big numbers that are easy to read to go into the headlamp:)
1977 CB 750 SS Cafe
1971 Mustang Grande
Offline kajtek
Re: Norwegian cafe
« Reply #143 on: September 22, 2010, 11:04:43 AM »
ive been looking at bicycle speedos and the biggest problem so far has been the backlight.. argh
ashley
1978 honda cb400f supersport
Re: Norwegian cafe
« Reply #144 on: September 22, 2010, 10:14:34 PM »
ashley
So not found any god yet, huh?:(
1977 CB 750 SS Cafe
1971 Mustang Grande
Offline kajtek
Re: Norwegian cafe
« Reply #145 on: September 23, 2010, 06:05:23 AM »
no afraid not... im leaning towards the simplest acewell digi system or the koso db01-r. from what i understand a lot of the bicycle backlights only come on if you press a button, and the ones with backlights tend to be more expensive, so might aswell get a bike one.
Re: Norwegian cafe.. Gsxr swingarm???
« Reply #146 on: September 27, 2010, 07:23:59 AM »
Anybody tried to fit gsxr 750 85 mod. rear swingarm to the 750?
1977 CB 750 SS Cafe
1971 Mustang Grande
Re: Norwegian cafe
« Reply #147 on: September 27, 2010, 01:41:32 PM »
Cut and ready to weld :) :) :D
1977 CB 750 SS Cafe
1971 Mustang Grande
Offline uthinkimodd
Re: Norwegian cafe.. Gsxr 750 swingarm??
« Reply #148 on: September 27, 2010, 03:33:22 PM »
Great looking build. With what you've done so far the swing arm shouldn't be that dificult. are you going to use a single shock or dual shocks? other than mounting it is all about spacing.
« Reply #149 on: September 28, 2010, 02:54:28 AM »
Thanks :) :)
The plan is to go with dual shocks, and incorporate the oil thank inside the swingarm. Have now cut it down to 1" over the original size. Have to cut out and move the "brace" at the back a little, to clear the wheel.. Then build a reservoir there:):)
1977 CB 750 SS Cafe
1971 Mustang Grande
