Author Topic: Norwegian cafe.. Oil tank in the swingarm....  (Read 98159 times)
Re: Norwegian cafe.. Gsxr swingarm???
« Reply #150 on: September 28, 2010, 03:00:07 AM »
Anybody tried to fit gsxr 750 85 mod. rear swingarm to the 750?
I have a 1988 GSXR 1100 swingarm cut down on one of my project Honda's..
Offline HedNut
  • Underwater Basket Weaving
Re: Norwegian cafe.. Gsxr 750 swingarm??
« Reply #151 on: September 28, 2010, 04:23:44 AM »
Oh...very cool stuff!
Offline lordmember1969
« Reply #152 on: September 28, 2010, 06:18:03 AM »
That's cool:) How did it fit? I think about the bearings and the fit to the frame? Any problems?
Build tread? :) :)
1977 CB 750 SS Cafe
1977 CB 750 Basket case
1971 Mustang Grande
1928 Model A Pheathon Hot Rod
1977 Harley Custom FXE
http://forums.sohc4.net/index.php?topic=70333.0
« Reply #153 on: September 28, 2010, 01:52:07 PM »
Still collecting parts for my builds, so no build thread yet. The swingarm was a direct fit into the frame, it was the correct width. It looks like you are cutting yours down similar to mine, you will have to, remove the monoshock mount and rebrace it but it is not a hard thing to do.  Have a look at the last couple of "Bike of the month" threads, there is a very nice 500 with GSXR 750 swingarm..
« Reply #154 on: September 28, 2010, 10:49:44 PM »
Thank you :) :) :)
1977 CB 750 SS Cafe
1971 Mustang Grande
« Reply #155 on: October 15, 2010, 03:33:54 PM »
You are right:):) It fits:):) This was almost to easy:) took some pictures, but my wife has cleaned  my desk and can not find the cable to the camera.. will try to post some tomorrow....
1977 CB 750 SS Cafe
1971 Mustang Grande
« Reply #156 on: October 15, 2010, 03:42:29 PM »
I am using a 43mm GSXR1100K front end as well and the Honda steering stem pressed straight into the GSXR clamps as well.....All too easy.... ;D ;D
« Reply #157 on: October 15, 2010, 03:50:55 PM »
Nice:) Do you have some pictures of that? I would love to see??
1977 CB 750 SS Cafe
1971 Mustang Grande
« Reply #158 on: October 15, 2010, 03:59:51 PM »
I only have a couple of old pictures of the whole bike, it is an expensive project and is taking me a long time to get all the parts, because i have no room , its all in boxes until i can get all the parts i need to finish it....Here's a couple of old pics of the front and swingarm.
The last picture has the stock swingarm, i was surprised to see that a 4.5 inch rim with a 170 tyre fit on, not much room but it did fit..
« Reply #159 on: October 15, 2010, 04:24:27 PM »
Nice:):) Cool build:) I will go for that front on my next one.. Maybe a mono shock setup from the gsxr with the gsxr wheels too:)
Thanks..
1977 CB 750 SS Cafe
1971 Mustang Grande
« Reply #160 on: October 15, 2010, 04:28:48 PM »
The only problem i have found with the suzuki front end is that the offset is shorter thasn the Honda clamps, this means that the forks either hit the tank or you end up with a larger turn radius.....I am looking at getting 43mm clamps made up eventually to the correct Honda offset....60mm i believe.
« Reply #161 on: October 15, 2010, 04:39:31 PM »
Can i go for a smaller tank. like the CB 500 i got on my project or is the offset way off?
1977 CB 750 SS Cafe
1971 Mustang Grande
« Reply #162 on: October 15, 2010, 04:57:52 PM »
To be honest, its not way off and i have just altered the steering stops so mine doesn't hit the tank,it has lessened the turning circle which doesn't really bother me but i also like to be manoeuvrable at slow speed, so i suppose it is just up too personal preference. A smaller or slimmer tank would also fix the problem....If you consider it to be a problem...The GSXR offset is around 32-35mm, the Honda K is 60mm and i think the F is 50mm..
« Reply #163 on: October 15, 2010, 05:12:54 PM »
I guess i just have to try it out:)
1977 CB 750 SS Cafe
1971 Mustang Grande
« Reply #164 on: October 16, 2010, 03:57:23 AM »
This is a very easy swap, have to modify the spacers.. But that is pretty much all :):)
« Last Edit: October 16, 2010, 04:03:35 AM by lordmember1969 »
1977 CB 750 SS Cafe
1971 Mustang Grande
« Reply #165 on: October 16, 2010, 04:05:48 AM »
Started to clean up under the seat:)
« Last Edit: October 16, 2010, 04:21:34 AM by lordmember1969 »
1977 CB 750 SS Cafe
1971 Mustang Grande
« Reply #166 on: October 16, 2010, 04:08:51 AM »
More swingarm pictures ;D
« Last Edit: October 16, 2010, 04:16:11 AM by lordmember1969 »
1977 CB 750 SS Cafe
1971 Mustang Grande
« Reply #167 on: October 16, 2010, 04:17:59 AM »
Maybe next project :) :) ;D
1977 CB 750 SS Cafe
1971 Mustang Grande
« Reply #168 on: October 16, 2010, 04:25:13 AM »
Rear light, almost done :) :)
« Last Edit: October 16, 2010, 04:40:30 AM by lordmember1969 »
1977 CB 750 SS Cafe
1971 Mustang Grande
Re: Norwegian cafe.. Oil tank in swingarm....
« Reply #169 on: October 16, 2010, 04:37:45 AM »
Want to have the oil reservoir incorporated into the swingarm :o :o ;D
It will hold 2 litres of oil, so will add more by adding an extra oilfilter hidden under the engine plus an oilcooler up front:)
« Last Edit: October 16, 2010, 04:54:23 AM by lordmember1969 »
1977 CB 750 SS Cafe
1971 Mustang Grande
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=rlab86rsenpcdld3tf0japst50&/topic,60973.0.html
« Reply #170 on: October 16, 2010, 09:04:18 AM »
fine idea to have oil volume lover then  the engine,,are you have a closed tank..or a breath and level point some higher..
or is it possible to make a dipstick,,on engine,, like the 550 and the smaller models vitaut oiltank...have faund an small generator from a racing car..send some pic..think it is hvat you need..
i hate all this v-w.... vords
« Reply #171 on: October 16, 2010, 03:03:33 PM »
Will use an oil cooler and a breath reservoir about the same height as the original oil tank level..Think it might work??:) Please send pictures of generator:) Interested in getting some more juice to run the fuel injection:):)
1977 CB 750 SS Cafe
1971 Mustang Grande
« Reply #172 on: October 16, 2010, 03:16:41 PM »
Started with messing with the wiring tonight, took more than one beer to find the curage to get started  ;D ;D Have no clue what i am doing:)
Pretty much #$%*ed here i think:)
Will probably need some help here... But think Honda could have saved millions on wires... :)It has to be possible to make the harness simpler??
« Last Edit: October 16, 2010, 03:20:27 PM by lordmember1969 »
1977 CB 750 SS Cafe
1971 Mustang Grande
Offline HedNut
« Reply #173 on: October 18, 2010, 06:38:27 AM »
Wow... your build is such an inspiration.. you do great fab work man!!  And YES..I think Honda could've saved a few $$ on wiring for sure!!
Keep it up!! Looking GREAT!!
« Reply #174 on: October 18, 2010, 06:58:38 AM »
This is the one i am going to put the frame kit on:):) Will strip it down and re weld the whole frame while i`m at it:)
« Last Edit: October 18, 2010, 07:26:11 AM by lordmember1969 »
1977 CB 750 SS Cafe
1971 Mustang Grande
