Author Topic: Norwegian cafe.. Oil tank in the swingarm....  (Read 99525 times)
Offline lordmember1969
Re: Norwegian cafe
« Reply #50 on: May 18, 2010, 07:24:44 AM »
Done welding the rear. Not decided on the design on the taillight yet. But this is how it looks so far :)
Taillight setup looks great. Go with that
Mike
Thanks Mike :)
1977 CB 750 SS Cafe
1977 CB 750 Basket case
1971 Mustang Grande
1928 Model A Pheathon Hot Rod
1977 Harley Custom FXE
http://forums.sohc4.net/index.php?topic=70333.0
Re: Norwegian cafe
« Reply #51 on: May 18, 2010, 07:37:20 AM »
Anyone tried welding the brake bracket to the fork?  :o
Wow, I have to say, this is one of my favorites.  Do you have or have you had it running on the EFI yet??  As far as the aluminum welding goes, this is a big deal when talking about brakes.  It really depends on the type of aluminum.  Please feel free to correct me if I'm wrong.  I 'm going off of memory, but I believe If its 50 or 60 series it is weldable.  However if it's 20 or 70 series it is not.  Most aluminum's I have worked with will take a weld and it will look vary nice.  Though, if the aluminum is not weldable it will usually stress crack right away along side of the weld.  That said, this doesn't always happen right away, it could hold for a long time and let loose at an inopportune time.  I propose for your safety and for the safety of everyone else you devise some sort of bracket instead of depending on an unknown or do some heavy research and find out the the makeup of the aluminum and know before you strike an ark weather or not it is weldable.  Just a suggestion ;D  That and about $75.00 at StarBucks will get you a cup of coffee.
Have not yet had it running, have to sort out the brakes first. As i understand from several other build treads about EFI conversions, the biggest problem is the manifolds the rest should be ok.. I hope :)? My Friend who is a professional welder, says it should be no problem regarding welding the brake bracket. Will try it out, I guess he know what he is talking about. :) But I will take your advice and secure it with a bracket on the back using the fender brackets. The rest is machined off.. I am pretty sure that the brakes will be safer than stock :)
Thanks again for the interest :)
« Last Edit: May 19, 2010, 06:28:26 AM by lordmember1969 »
1977 CB 750 SS Cafe
1971 Mustang Grande
Re: Norwegian cafe
« Reply #52 on: May 20, 2010, 02:26:36 PM »
Very pleased with the welding of the brake bracket :)
Some more grinding and polish and it will look alright:)
Tack welded first with all the parts in place to get it in the right , then took it apart and welded all :) Cleaned all oil and dirt out of the tube first.  :) But go to a professional welder to do this :)
« Last Edit: May 20, 2010, 02:35:05 PM by lordmember1969 »
1977 CB 750 SS Cafe
1971 Mustang Grande
Re: Norwegian cafe
« Reply #53 on: May 24, 2010, 03:44:44 AM »
Anyone know what to use to put this together ? PO cut away the chrome ring to get inside, can i get a new one or make something to hold it together?
Thanks
1977 CB 750 SS Cafe
1971 Mustang Grande
Offline Flying J
Re: Norwegian cafe
« Reply #54 on: May 25, 2010, 09:56:14 PM »
beats me but im watching to see how it all ends up. :)
Offline joe1028
Re: Norwegian cafe
« Reply #55 on: May 26, 2010, 05:19:33 AM »
nice to see a ground up build with your own parts without buying all the parts and assembling it like a kit bike....do you think the suzuki shift lever will work? i just flipped the stock shift lever over and used it that way as i did not have one that would work( i bought a box of different used japanese rearsets off ebay)...joe@vcycle
Re: Norwegian cafe
« Reply #56 on: May 26, 2010, 08:01:30 AM »
The shifter won't work the way they came, had to mill and weld a bracket for the shifter to the footpeg mounts. Still have to modify some to make it work:) Will post pictures when I have figured it out:)
The footpegs and shifter are from Honda cbr 1000 04-07 i believe:) Not Suzuki.
1977 CB 750 SS Cafe
1971 Mustang Grande
Re: Norwegian cafe
« Reply #57 on: May 26, 2010, 08:06:24 AM »
I read somewere to JB weld the ring that was there, but I do not have it? So if anyone have any suggestions i would be happy:):)
1977 CB 750 SS Cafe
1971 Mustang Grande
Re: Norwegian cafe
« Reply #58 on: May 26, 2010, 09:38:07 AM »
Thanks to Dakota, he gave me a tip about these :) :) :)
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=300418944904
1977 CB 750 SS Cafe
1971 Mustang Grande
Offline HondaNorway
Re: Norwegian cafe
« Reply #59 on: May 26, 2010, 03:17:52 PM »
To the norwegian sohc-rider:  ;D
De selger det her: http://www.gasolin.no/index.php?main_page=product_info&products_id=137
Men jeg mener også å ha kjøpt det på clas ohlson en gang. Har det sikkert på Torshov bilrekvisita o.l
-Stian, Trondheim
 :D
« Last Edit: May 26, 2010, 03:21:22 PM by HondaNorway »
'74 CB750
'76 CB750F
Re: Norwegian cafe
« Reply #60 on: May 27, 2010, 01:14:41 AM »
-Stian, Trondheim
 :D
Takker for det Stian :) Kjekt og se at det er flere Trøndere på dette forumet :) Skal sjekke Clas Ohlson neste gang jeg er i Trondheim :)
Mangler ringen for og lime, men nyttig og vite:)
Robert, Namsos
1977 CB 750 SS Cafe
1971 Mustang Grande
Offline CPHjimm
Re: Norwegian cafe
« Reply #61 on: June 01, 2010, 02:26:20 AM »
Nice project you got going there!! How much did the tube deform after the welding? would like to see a straight edge on the other site? planning on doing the same on my spare forks
\m/ [(-_-)] \m/
Re: Norwegian cafe
« Reply #62 on: June 01, 2010, 07:11:38 AM »
Thanks :) :)
The fork did not deform at all :) When i look inside the tube it has the same mirror like surface as before, can not see any deformation .. guess it depends on the welder, but mine seems alright :) :) Can try to take pictures for you.. ?
But there will always be an risk of destroying your fork . But done right i think it will be fine.
1977 CB 750 SS Cafe
1971 Mustang Grande
Re: Norwegian cafe
« Reply #63 on: June 02, 2010, 01:30:56 PM »
[/quote]
Here you go CPHjimm :)
Inside forktube after welding:)
Outside:)
« Last Edit: June 02, 2010, 01:36:44 PM by lordmember1969 »
1977 CB 750 SS Cafe
1971 Mustang Grande
Offline CPHjimm
Re: Norwegian cafe
« Reply #64 on: June 03, 2010, 02:32:14 AM »
Thanks... i sure looks great!! I will get started soon with my AC/DC Welder.
\m/ [(-_-)] \m/
Re: Norwegian cafe
« Reply #65 on: June 25, 2010, 09:54:08 AM »
Do anybody make, or know any who make and sell custom wiering harness  for the 750? Want as little/simple  as possible, no signal lights, warning lights, instruments, or hand controls.. Just the basic ? :)
1977 CB 750 SS Cafe
1971 Mustang Grande
Offline Flying J
Re: Norwegian cafe
« Reply #66 on: June 25, 2010, 10:12:35 AM »
Im doing the wore harness on mine but im updating all the 30+ y/o electrical parts. I got 1 of the regulator/rectifier and im going to run a marine circuit breaker instead of a fuse panel.
Re: Norwegian cafe
« Reply #67 on: June 25, 2010, 10:23:01 AM »
Cool:)
Thanks for the help on the wiring diagram, looks pretty straight forward:) Electrics is my weak side :( Will upgrade a change as much as possible.. Make things simple...
1977 CB 750 SS Cafe
1971 Mustang Grande
Offline HedNut
  • Underwater Basket Weaving
Re: Norwegian cafe
« Reply #68 on: June 25, 2010, 10:46:36 AM »
Wow...great work on this bike!! I'm watching this one eagerly!! cheers!
Re: Norwegian cafe
« Reply #69 on: June 25, 2010, 11:11:40 AM »
Thank you:) I have been thinking of getting one off your frame kits.. Are they available? and does it do anything to the rigidity/stiffness of the frame? cheers !:)
« Last Edit: June 25, 2010, 11:13:39 AM by lordmember1969 »
1977 CB 750 SS Cafe
1971 Mustang Grande
Offline HedNut
Re: Norwegian cafe
« Reply #70 on: June 25, 2010, 11:33:46 AM »
Cheers!  For the frame kits...I'm building a list of people who want them before getting the next batch made. Need a few more names and I'll get them going.  (take 1-2 weeks to get a run machined, assembled and sent out)...I wish I could keep stock...but am not in the best place to do that right now.
As for rigidity... I believe they are over engineered for what is required of them, and have no worries about running the bike with a Gordon kit installed, as they are quite beefy.   Although many people will argue that any cutting of the frame will skew it's original rigidity...you can read thru the discussions and forum members comments.   I haven't heard one complaint from somebody who has installed the kit yet....and I don't think Gordon has either...since he started making these years back.
Let me know if you're interested and I'll put your name on the list...hopefully get some going soon.
Brendan
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=hjt7qqsnf7p10htne86dugr2o3&/topic,60973.0.html
Re: Norwegian cafe
« Reply #71 on: June 25, 2010, 11:43:32 AM »
hej det ser godt ud..jeg skal engang på ferie i hønefoss området..er i langt derfra..kunne tage min 550 eller 400 med derop..det bliver tideligst 2011
i hate all this v-w.... vords
Re: Norwegian cafe
« Reply #72 on: June 25, 2010, 12:00:35 PM »
Hei:) Og takk for det. Hønefoss ligger et stykke sør i landet ca 60 mil fra der jeg bor. Men går alltids og møtes hvis ting stemmer:) Har du bilder av syklene dine på forumet? :)
1977 CB 750 SS Cafe
1971 Mustang Grande
Re: Norwegian cafe
« Reply #73 on: June 25, 2010, 12:07:52 PM »
Brendan
Put me on the list:)
1977 CB 750 SS Cafe
1971 Mustang Grande
Offline strynboen
Re: Norwegian cafe
« Reply #74 on: June 25, 2010, 12:49:30 PM »
hey,,ja...søg på strynboens 550 og strynboens 400f 1975...jeg har familie i hønefoss,,så vi er der årligt..men er ikke kørende før neste seson..men vil gerne cruise en tur i de flotte bjerg veje
