Author Topic: proper carbs?  (Read 2278 times)
Offline Zig
proper carbs?
« on: May 08, 2010, 03:22:50 PM »
the rack of carbs im working with (came out of a box of spare parts) are stamped "657b" are these the proper carbs for 750 k5?? just thought i would ask before i spend a million dollars on rebuild parts.
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
Re: proper carbs?
« Reply #1 on: May 08, 2010, 03:26:10 PM »
Do you have a camera?
Offline Zig
Re: proper carbs?
« Reply #2 on: May 08, 2010, 03:32:49 PM »
pic already posted in "project beginning" but here is another.
waddya think seaweb?
« Last Edit: May 08, 2010, 03:48:41 PM by Zig »
Offline harleyhonda bobber
  • 78 cb 750k
Re: proper carbs?
« Reply #3 on: May 08, 2010, 04:21:20 PM »
numbers for those carbs are coming up as 1975 cb750 f
Offline Zig
Re: proper carbs?
« Reply #4 on: May 09, 2010, 12:57:08 AM »
are they interchangeable with the K series?
what do i have to do to make them work, i assume jetting is different?
« Last Edit: May 09, 2010, 01:05:32 AM by Zig »
Offline Zig
Re: proper carbs?
« Reply #5 on: May 09, 2010, 08:52:00 PM »
any opinions?
Offline BeSeeingYou
Re: proper carbs?
« Reply #6 on: May 09, 2010, 11:14:33 PM »
I think the stock jetting is the same as the K5 with 105 mains and 40 idle.  I believe the emulsion tubes are different with the F tubes being an improvement so it would be an upgrade IMO.  One member mentioned in another thread recently that he had a noticeable improvement when he put the needles and emulsion tubes from an F into his K.  I would think they would fit.
Offline Zig
Re: proper carbs?
« Reply #7 on: May 10, 2010, 09:22:50 AM »
thank you.
  • 78 cb 750k
Re: proper carbs?
« Reply #8 on: May 11, 2010, 02:45:32 AM »
if they will mount onto your intake they should work...chopper teck has all the specs from float height, to main ,and slow jet numbers :-\
Offline mystic_1
  • 1970 CB750K
Re: proper carbs?
« Reply #9 on: May 14, 2010, 06:57:04 PM »
I have a 1970 CB750K0 and I'm running 657b carbs.  :)
mystic_1
- John Augustus Shedd
