Author Topic: help, strange connector  (Read 573 times)
imsam817
« on: May 08, 2010, 06:20:28 PM »
anyone have a clue as to what this connector is for?  my old harness was chopped up pretty bad by the po, so i had to buy a used replacement harness, think its from a k not an f though...
oops forgot to mention its for a 550
« Last Edit: May 08, 2010, 06:29:19 PM by imsam817 »
Re: help, strange connector
« Reply #1 on: May 08, 2010, 06:43:31 PM »
What year is the bike, and what year is the harness? From what I can see of the wire colors, I'm making an educated guess that it goes to the Starter Motor Safety Unit (SMSU), which will not allow the electric starter to operate unless the clutch lever is pulled in, or the trans is in neutral, or both. They were used from '73 to '77 cb750s, and I suspect also on 550 during the same years. If you don't have the SMSU, or the switch in your clutch lever, not much of a problem; it can be jumped to allow proper operation of the starter.
imsam817
« Reply #2 on: May 08, 2010, 06:45:29 PM »
its for a 77 cb550, i had a feeling it was for something like that, but it doesn't show up in any of the diagrams...
