Author Topic: Chevy torque converter rattle... help?  (Read 10981 times)
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
« on: May 09, 2010, 02:56:27 PM »
I pulled the torque converter on my 95 GMC 2500 van
it's a 350 with a 4L60E (700R4).
I haven't worked on automatics in about 10 years and I forgot some details.
My question is, is the internals of the torque converter supposed to rattle around in there?
video coming when it finishes uploading.
« Last Edit: May 09, 2010, 03:02:21 PM by Industrial Cafe »
Offline bucky katt
  • i am a pastafarian!
    • facebook
Re: Chevy torque converter... help?
« Reply #1 on: May 09, 2010, 02:57:14 PM »
no. bad needle bearings most likely.
Mark Twain - Notebook, 1894
  • Like a well oiled
    • Undead Asphalt
Re: Chevy torque converter rattle... help?
« Reply #2 on: May 09, 2010, 03:14:55 PM »
I figured that.
From the day I got the van, the tranny shifted hard into drive or reverse.
 When I say hard I mean it went "BANG" into gear.
the previous owner said  "It's done that ever since I got the transmission rebuilt"
    Then it started clicking from the bell housing, but it still moved, so I pulled the shield off and laid down under it for a few seconds and I heard a "KA-CHUNK!" from the converter to which my response was to immediately soil myself... hard.
the clicking was gone but it didn't move anymore when placed into gear.
my father in law tried to blame me for it because of a 3 second burn out I did. ::) ::) ::) literally, I burned them for 3 seconds as part of a ''family guy cut away'' for a video I was making.
I've done 253,761 burnouts in my life and never broke anything.
                                   EDIT: I broke a u-joint doing a neutral drop when I was a kid.
                                           smashed the drive shaft through the floor of my Oldsmobile.
« Last Edit: May 11, 2010, 06:06:34 AM by Industrial Cafe »
  • Like a well oiled
    • Undead Asphalt
Offline bucky katt
    • facebook
« Reply #4 on: May 09, 2010, 08:25:02 PM »
i've never had one that made that sound, you lost a bearing or bushing. try a used torque converter and see.
« Reply #5 on: May 10, 2010, 11:54:12 PM »
The guy that rebuilt the trans may have forced it together without the lugs being engaged.  then started it.
  • Like a well oiled
    • Undead Asphalt
« Reply #6 on: May 11, 2010, 06:00:26 AM »
I can't believe the prices on these things! $150+ for a stock one, $250+ for "performance"
I surfed around the web and picked one up for 72 shipped.
It's a 1650 stall with lock-up and brazed fins, stock is 1425 no lockup no brazing, so it should provide me with better fuel in the cruise and better jump off the line.
we'll see when it gets here...
Offline chrislib
« Reply #7 on: May 11, 2010, 03:42:57 PM »
Ck the flexplate and make sure it isnt cracked/broken.
Chris...closet Idlefiddler
#1975
1973 CB750K...CANDY BACCHUS OLIVE
  • Like a well oiled
    • Undead Asphalt
« Reply #8 on: May 11, 2010, 06:47:10 PM »
k
  • Like a well oiled
    • Undead Asphalt
« Reply #9 on: May 14, 2010, 11:58:28 AM »
OH GOD! it's the oil pump.
the fingers on the oil pump are broke off!!!!!!!!!!!!!!!!!!!!!!!!!!!!!11111 Shift one one
Offline bucky katt
    • facebook
« Reply #10 on: May 14, 2010, 01:15:37 PM »
oooooooooooohhhhhhhhhh front pump toasted. thats bad.
  • Like a well oiled
    • Undead Asphalt
« Reply #11 on: May 14, 2010, 04:41:42 PM »
I wonder why?
 It's so shiny and new...
  • Like a well oiled
    • Undead Asphalt
« Reply #12 on: May 18, 2010, 11:24:39 AM »
I need a whole new oil pump.
                                       I think it's called "catastrophic failure"
the fixed splines on the stator shaft (where it connects to the stator inside the converter) are worn ''narrow'' as well.
there's a deep gouge in the pump housing too
YAY!  fun stuff.
Offline bucky katt
    • facebook
« Reply #13 on: May 19, 2010, 12:11:40 PM »
putting 500+ bhp through a th350 i didnt see that kind of wear or breakage!
« Reply #14 on: May 20, 2010, 09:33:48 PM »
I put almost a thousand HP through a powerglide and thank goodness it hasn't done that yet, but it probably cost as much as a good used van. Oh, and a 1300 dollar freshen up after 150 runs. counting warm up and return road about 100 miles. There, did that make you feel better?
Offline axehole54
  • Who the heck decided to call me a
  • #169 North
« Reply #15 on: May 20, 2010, 11:19:00 PM »
In high school I mated a peppy 350 to an old 3spd standard in a 64 pontiac strato chief... Side stepped it into second twice... now that was catostrophic failure lol...   pieces on the road and the trans locked the driveshaft so bad I thought the rear end siezed initally...  lesson noted (probably not learned) ;D
73 750k, 78 750k, 69 c10, 87 r1500 (c10), 94 fzr1000
  • Like a well oiled
    • Undead Asphalt
« Reply #16 on: June 24, 2010, 06:33:05 PM »
ok, so I think I got the problem resolved....
I got a new oil pump and slapped it all back together, we'll see if it's all better now....
Offline GammaFlat
« Reply #17 on: June 24, 2010, 09:18:20 PM »
About a million years ago I was involved in a trans swap.  It was a Turbo 350 mated to a Chevy 350.  Whilst installing the torque converter, great care must be taken to rotate the converter so that it properly mates with the trans.  It makes a decided clunk and drop into the trans.  The problem can come in when you tighten the engine up to the trans without doing this.  Everything will tighten up nicely and your front pump on your trans will take a fatal wound.  I'm not sure if that's the same problem you had there.
K6
85 Goldwing
  • Like a well oiled
    • Undead Asphalt
« Reply #18 on: June 24, 2010, 10:33:08 PM »
the tranny was rebuilt when it was in the hands of the previous owner, by a shop no less.
   The PWM-TCC solenoid was disconnected and it made the transmission shift unbelievably hard into reverse, drive, and second.
             that solenoid is told by a pulse width modulator when to do some dumb computer robot #$%* to the torque converter clutch
with it disconnected the torque converter was in a lock situation at idle, breaking the fingers on the pump (unless the shop did that when they bashed everything together)
   Another issue I encountered was one of the two fingers on the first band was bent and the valve body gaskets weren't lined up properly.
you could see the damage from the hard shift engagement on the fingers of the clutch packs for 2nd gear.
the whole job was a pain and everything is heavy and awkward, but I had fun learning about how an automatic goes together...
« Last Edit: June 24, 2010, 10:34:44 PM by Industrial Cafe »
  • Like a well oiled
    • Undead Asphalt
« Reply #19 on: June 25, 2010, 09:07:36 AM »
fixed.
