Author Topic: K or F, F or K. Can't decide  (Read 1353 times)
Offline laser145
  • underfunded
« on: May 09, 2010, 04:12:16 PM »
I'm looking to purchase a 750 once I sell 2 other bikes and I just can't decide between the K or F.
Appearance wise, I prefer the K0-K6 bikes to the super sports.  And If I end up going to K route, I'm likely to keep it pretty close to stock.
But I like the dual disk setup on the F bikes, and I like the tank...I just don't like the tail...so If I go with an F, I'll probably modify it more
I'm also intrigued by the extra power the F bikes provide...I've never been on one though
I guess my ideal bike is an early K but running a dual disk up front...
Anyone with experience on both, is either one better for distance riding? I'm upgrading to a larger bike partly b/c I want to get out on longer trips...
scrapvalue
Re: K or F, F or K. Can't decide
« Reply #1 on: May 09, 2010, 04:20:12 PM »
Don't think you could go wrong with either one.
Wouldn't turn down either if they were in good working condition or the price was right for a fixer upper.
This one just came up in S. Michigan. If I had a little extra coin, I would go get it.
If anyone else is interested, check it out.
http://nmi.craigslist.org/mcy/1729994840.html
Offline laser145
  • underfunded
« Reply #2 on: May 09, 2010, 06:03:06 PM »
I'm trying to focus on 76 or earlier K models, as well as the F's...
Truth be told, I'll probably just go with the first nice one I find for a good price...just let fate figure it out for me.
scrapvalue
« Reply #3 on: May 09, 2010, 06:53:09 PM »
Good call.
Offline GammaFlat
« Reply #4 on: May 09, 2010, 08:05:38 PM »
I'm with ya on the slight bias toward K's but F's are sure nice too.  An advantage of the K's is parts availability.  K parts are easier to get.
K6
85 Goldwing
Offline Spanner 1
« Reply #5 on: May 09, 2010, 08:17:27 PM »
F's and 'A's have a longer wheelbase and handle noticeably different ( better ) than than K's....IMO.
Offline mystic_1
  • 1970 CB750K
« Reply #6 on: May 09, 2010, 10:00:46 PM »
You can put a dual disk on a K2 through K6 pretty easy.
mystic_1
- John Augustus Shedd
Offline BeSeeingYou
« Reply #7 on: May 09, 2010, 10:36:18 PM »
The 77/8 F bikes are the ones with the dual disc up front.  They also have a problem with valve guide wear so a top end job may have to be factored in depending on mileage.  This is not an issue with the 75/6 F.  Like Spanner said the revised frame geometry of the F improves the handling and gives it better straight line stability than the K.  The only drawback to my mind of the F for touring is the higher gear ratio in 4th and 5th.   You will be running a few hundred rpm more at highway speed but this can be overcome with a change in the rear sprocket if wanted.  The tail does provide a nice storage place for tools, spares, etc.  I have had a limited amount of time on a few K bikes and have come away with a preference for the F but I think either would be a good choice.
Offline laser145
  • underfunded
« Reply #8 on: May 10, 2010, 04:51:30 AM »
mystic_1
This is something I was wondering about.  I've seen a few of the K's around with this done.  Are people generally swapping the front end with that of a 77/78F (or other bike), or are they simply modifying the front forks and wheel to accept a dual disk?
« Reply #9 on: May 10, 2010, 12:21:56 PM »
either way can be done.
Offline greasy j
  • lanesplitting
  • non serviam
« Reply #10 on: May 10, 2010, 12:24:14 PM »
as far as engines go, the earlier ones have much better heads. pre '72. they did more work on them and they get more HP.
I have a 71 K1. greatest bike ever made.
