Author Topic: Master cylinder circlip removal tool  (Read 4817 times)
Offline cookindaddy
  • I sure love this bike!
« on: May 10, 2010, 10:27:14 AM »
I bent a piece of 3/16" steel rod into the shape shown to push down the piston in the end of my 78 CB750K master cylinder so that tension was released from the circlip so that I could remove it. The trick was to not get in the way of the circlip pliers.
This worked great for me in case you can use the idea.
I'll also use the tool to hold the assembly into the bore when I re-insert the circlip.
George with a black 78 CB750K (in Lion's Head, Ontario, Canada)
Offline xenoscr
  • 1975 Honda CB750 K5
Re: Master cylinder circlip removal tool
« Reply #1 on: May 10, 2010, 10:33:53 AM »
Awesome idea! I struggled when I tried to dismantle my original MC. I hope this makes it to the FAQ, it could be quite helpful.
XeNoS
1975 Honda CB750 K5
Offline Tom in Newcastle......Ontario
  • Newcastle Ontario
« Reply #2 on: May 10, 2010, 04:34:01 PM »
Have to remember that one...I used to put the lever bolt in and then a screw driver to hold the piston down ,but that only left me with one free hand.yours is a much better idea
1978 cb 550k......stock,my first re-build
Loud pipes suck.......
If you buy something.........pay for it !
If you sell something .......ship it !
If you say you are going to do something......do it !
If you have a question about something......ask it !
When the seller answers ........let him know whether you still want it or not !
If you receive something .....let the seller know you got it !
If you get something and are happy/un happy with it .....let the giver/seller know !
If you have any kind of issue,shipping/receiving/quality/price/shipping charges etc !
Communicate
Offline mycb750k6
  • "res ipsa loquitur"
  • Rocketman
    • photobucket albums
« Reply #3 on: May 10, 2010, 05:21:56 PM »
I drilled an 1/8th inch hole through the mirror hole all the way through (who's gonna see it) and then stuck a 1/16th nail through the hold the piston down. Plenty of room to maneuver in there with just a small nail sticking in from where the mirror screws in. FWIW. For putting the cir-clip back in I machined a piece of nylon just big enough to fit in the hole to push the cir-clip down with a hole in the business end of the nylon the size of the piston. One whack with a rubber mallet and the cir-clip is in.
