Author Topic: Synching Carbs Question  (Read 1980 times)
Offline campbmic
  • Sea-Foam and Flaming 151 is a dam good
« on: May 10, 2010, 04:45:16 PM »
I'm trying to synch my carbs using an old motion pro mercury monometer and have some questions. I've been trying to tune my carbs at about 1.5-2k RPM;
-What RPM should I set my bike to when synching the carbs?
-I have lots of little bubbles in my mercury and when the bike starts some of the lines of mercury have lots of air spaces in them. Should I just take the reading at the top of the mercury or do I need to fix this?
-My mercury levels are constantly bouncing around and I can here my engine speed slowing and speeding up constantly how do I stop this?
-I know the bike should be warmed up before synching but should the choke lever be up or pushed down while synching? (Im guessing pushed down)
« Last Edit: May 10, 2010, 05:57:14 PM by campbmic »
Its hard to be wrong when you know nothing!
Offline westondc
  • Wes Mantooth
Re: Synching Carbs Question
« Reply #1 on: May 10, 2010, 04:53:31 PM »
-What RPM should I set my bike to when synching the carbs? i try at idle, then at about half throttle
-I have lots of little bubbles in my mercury and when the bike starts some of the lines of mercury have lots of air spaces in them. Should I just take the reading at the top of the mercury or do I need to fix this? need to fix this for a correct reading, try tapping on them
-My mercury levels are constantly bouncing around and I can here my engine speed slowing and speeding up constantly how do I stop this? you need to use the dampeners, small twist valves that should be installed on each tube to the carb
-I know the bike should be warmed up before synching but should the choke lever be up or pushed down while synching? (Im guessing pushed down) should be warmed up to the point where the choke is fully open
B.O.X.N.I.F.E. Hospital fund https://www.everribbon.com/ribbon/view/8352
Rider no. 115 on the 2012 SOHC/4 Honda World Tour
Rider no. 274 on the 2011 SOHC/4 Honda World Tour
1972 Honda CB500k1
1971 Honda CB350k3
the project http://forums.sohc4.net/index.php?topic=64499.0
Trip/Project Blog http://easterntowestern.blogspot.com/
just be a vagabond, living out of a backpack on a little Honda, cruisin all over the damn place....
"As your attorney, I advise you to buy a motorcycle. How else can we cover a thing like this righteously?"
Offline Steve_K
« Reply #2 on: May 10, 2010, 05:53:31 PM »
With my mercury tool  I loaned it out and  when it came back the mercury was sucked out and I had bubbles and it was no longer any good.  I use 1000 to 1500 RPMs to sinc carbs.  Mercury is no longer available to buy.  I am afraid your sync tool is not working and without  a refill it will not work.  Yeah, I tried with mine. Not good.  I brought the Motion Pro new one without mercury and you need to be careful about sucking that out, too,  I wish I went with the more expensive vacuum gages.  I hook up only after the the bike is warmed up.  Use a fan on the engine.  Keep the RPMs down when blipping the throttle.  Important to do after adjusting the linkage.
Good luck!
Steve
Steve_K
Offline campbmic
« Reply #3 on: May 10, 2010, 05:57:01 PM »
The mercury on this syncher got poured out and I was able to get some more. I've tapped the heck out of the tubes and there are still bubbles in them. I guess I just need to get a new tuner! Thanks for the input!
