Those coils fit into that space when the bike came from Honda, so they should fit now. Yes, the wires tend to get stiff, especially when they are cold, but unless the insulation is cracked, or damaged, they will work fine. Look closely where the wires come out of the coils. If no cracks, you should be OK. People have posted ways to replace wire with a special splice if there is enough good wire, and others have posted methods for replacing the whole wire inside the coil. After-market coils are available, too.
