I know this thread is old, but I found it while searching for points info.
Honda always and only used TEC and ND points. Reason: they are the only ones that don't suck.
"A word or two about the points assemblies themselves. Honda used only two brands of points on the SOHC Fours: TEC (Toyo Electrical Company) and ND (Nippon Denso). These points are best because they're made the best: the pivots have the least slop, the steel bracket is the stoutest and flattest, and the contacts are the most resistant to burning. There are of course several aftermarket point assemblies available to fit the SOHC Four, among them Mitsubishi and Diachi, but Honda never used these inferior products as original equipment on the Fours. Their poorly stamped, light gauge, rounded backs cause them to change timing when the screws are tightened, their springs are not as firm, and their insulating washers are flimsy. In a word, they're junk." --
Mike NixonAlso, Re: Bike Bandit. I order from them most times I need something. They're close and they're cheap and they make stuff pretty easy to find.
