Author Topic: chain and sproket 78 750f  (Read 752 times)
Offline g_lightning
« on: May 11, 2010, 02:15:00 PM »
I have absolutely no understanding on ratios and the amount of teeth on a sprocket.
I need someone (anybody?) to give me a chain size to get and the sprockets to get with it.
I have no idea of what to purchase and could desperately need your help.
Please let me know what I should do.
Thanks again for your help!!
Offline g_lightning
Re: chain and sproket 78 750f
« Reply #1 on: May 11, 2010, 02:18:21 PM »
Oh and yes I used the search function but didn't really find what I was looking for.  :-\
Offline BlindJoe
« Reply #2 on: May 11, 2010, 02:41:49 PM »
"Please let me know what I should do." Search more better
stock is 15 front, 41 rear, 630 chain
http://forums.sohc4.net/index.php?topic=372.0
Offline g_lightning
« Reply #3 on: May 11, 2010, 03:59:51 PM »
Thank you for the stock specs of the bike.  I was hoping to find stock replacements because I thought that it would be the easiest swap.  The stock chain has 88 links???
Offline BlindJoe
« Reply #4 on: May 11, 2010, 04:10:09 PM »
yep
Offline BlindJoe
« Reply #5 on: May 11, 2010, 04:17:25 PM »
oops i think it might be 14 front, and 43 rear for the F, sorry
Offline g_lightning
« Reply #6 on: May 11, 2010, 04:17:43 PM »
Thx
Offline bender01
« Reply #7 on: May 12, 2010, 08:09:12 AM »
http://forums.sohc4.net/index.php?topic=62798.0
  This might help. That 630 chain is expensive. this can be done for  around $100 .
75 550 K1
74 750 K4
1968 450 K1 Super Sport
74 750k 836 project
Good luck!
Two Tired Quote !
Offline kvallelunga
« Reply #8 on: May 12, 2010, 10:57:34 AM »
I used a 16/45 with I think 88 links but would use either 16/44 or 16/46 because the chain didn't fit the way it should. I had to either use a half link or jam the wheel all the way forward and still not be able to get the chain off without removing the master link.
I run about 5000 rpm at 80. It's a little high but pretty peppy in town.
« Last Edit: May 12, 2010, 11:04:41 AM by kvallelunga »
78 CB750 F Supersport
81 Yamaha Chappy
