I went out last night and got a new relay from Advance and was able to get the front ones working. Strange thing is that they are working without resistors on them.
![Huh ???](http://forums.sohc4.net/Smileys/default/huh.gif)
Now the problem is when I remove the rear bulb flashers and put on the second set of LEDS both the front and rears just stay lit when I flip the signal switch. No blink. I am going to search the forums today, while the boss's back is turned
![Grin ;D](http://forums.sohc4.net/Smileys/default/grin.gif)
, and see if I can come up with a solution.
I have heard that there are special flash codes the bikes use to indicate electrical problems. One I heard is that they all flash when one is unpluged. Does anyone know if these codes are true and where to get a guide on how to decipher them?
