Author Topic: I need help with a car. ASAP!  (Read 3509 times)
Offline mgbgt89
Re: I need help with a car. ASAP!
« Reply #25 on: May 14, 2010, 05:28:01 PM »
im with traveler,if you can open it up ,empty it and close it to look legit,ive never had a cat equipped car!(73 holden)
You can either just hollow them out, or if you want to get real fancy, hollow it out and then put a pipe through the center of it so you don't have an echo chamber.
« Reply #26 on: May 15, 2010, 01:26:00 AM »
we dont have smog testing here,however any smog equipment must be present and working on the car if it was factory fitted,mine only has a pcv valve,no charcoal can even,our cars never got airpumps either,we sort of skipped that and ended up with fuel injection and cats.we had lean burn and egr through the late 70s into 80s as well as retarded ignition advance governed by temp and gear position and other fiddly stuff that fails.,so long as your cars not blowing blue smoke its ok.australia wide.
« Last Edit: May 15, 2010, 01:30:28 AM by dave500 »
