Author Topic: 1973 CB500 Headlight on/off switch question...  (Read 2871 times)
Offline Taylor
« on: May 13, 2010, 08:39:48 PM »
Hello all,
Proud new owner of a 73 cb500. The owner before me hacked up the harness and there were many electrical bits that were not working. I have spent the last week fixing them all, but there is one that still eludes me. My bike has a on/off for the headlight on the right hand bar. It looks like there is a brown, white and yellow that are used to interrupt the headlight somehow, these three wires come from the RH swtich and are sitting disconnected behind the headlight in the rats nest of wires. SOOOOOOOO I am wondering where these wires need to go to make it so the on/off switch will function as intended . I have the wiring diagrams for the 500 but I don't see the on/off switch in it. Everything on the bike now works perfectly except for this dang switch!
Thank you!
traveler
Re: 1973 CB500 Headlight on/off switch question...
« Reply #1 on: May 13, 2010, 09:01:47 PM »
If they are on the RIGHT side, then it is NOT factory.  From the factory all lighting control is on the left switch, and the light is always on, with only a high/low beam switch being present.  Looking at your switch, you have 3 wires.  Now, what you need to find out, and you can do this with a ohmmeter, is find out which wire is your high beam on the switch and mark it, or write down the color of the wire.  Next, do the same for the low beam.  The other wire must be the incoming power from the lighting circuit.  OR, someone used a off color wire as a ground.....in short you gotta be able to trace the wiring, and you gotta be able to actually "see" what it is you are talking about.
without pics.....diagnosing this is like ray charles trying to do heart surgery.
~joe
« Last Edit: May 13, 2010, 09:03:38 PM by traveler »
Offline Taylor
« Reply #2 on: May 13, 2010, 09:45:41 PM »
I will try and post some pictures tomorrow. But the High/Low switch is on the left, this is working fine. The on/off switch is on the right hand side, I thought this was standard till the later 70's models when they made the headlights remain on all the time. Its a 73 btw.
traveler
« Reply #3 on: May 13, 2010, 09:47:24 PM »
All I would do is really go over the wiring diagram, get an ohmmeter, amd start in on it.
~Joe
Offline Taylor
« Reply #4 on: May 13, 2010, 10:04:47 PM »
I have used multiple wiring diagrams and none show the on/off switch wiring on the right hand side that were specific to earlier CB500's. I have been though the whole bike with an ohm meter... its how i fixed the other dozen problems with the electrical system.  This is my last hurdle and I was hoping for a short and sweet answer. If anyone out there has a diagram for the right hand side on/off headlight switch this would help me immensely!
-Taylor
Offline boulder74
  • '75 CB 500 Cafe...almost done
« Reply #5 on: May 14, 2010, 07:58:07 AM »
This is just a noob opinion but I have the exact same bike and my headlight switch & starter are on the right and the turn signal & horn are on the left.  My stuff is definitely stock and the headlight switch is just for high/low control.  I can't actually turn the light off.  Hopefully this helps.  I could check the wiring if you get really stuck.
good luck...
Gotta love POs
Offline weekend_junkie
  • I bet you think I'm some
  • Member # 15859
« Reply #6 on: May 14, 2010, 08:27:42 AM »
~joe
I gotta jump on you for that response.  My '73 CB350 has an off-low-high headlight control on the right side and no light control on the left side.  Furthermore, my dad's '72 CB500 had the same control.
On top of that, who's to say it's not a european bike that has an original headlight off-siwtch?
@boulder74 - trying pushing the switch down a little and to the left.  You might be surprized that you have an 'off' position.
Dan
Offline Taylor
« Reply #7 on: May 14, 2010, 09:25:41 AM »
Here are some pics
Offline 333
  • Time for change
« Reply #8 on: May 14, 2010, 10:25:24 AM »
I'm wondering if the PO put different bars and switches, changing it from a single off-low-high switch on the right to a on-off on the right, and high-low on the left.  That would certainly cause confusion.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline eideteker
« Reply #9 on: May 14, 2010, 02:48:12 PM »
I also have a '73 CB500 and I wanted to chime in on the right-hand switch location and off-low-high positions.
"Spit on the tip of your finger, lube the inside of the hole, and then wiggle it around and twist a bit back and forth as you apply pressure." - mystic_1
1973 CB500K - not bad for a first bike
2009 SFV650 - torquey, reliable 90° V-twin
Offline Taylor
« Reply #10 on: May 15, 2010, 12:48:02 PM »
Hmmm.... well If these aren't stock anybody know where their from by chance?
  • Member # 15859
« Reply #11 on: May 15, 2010, 04:35:48 PM »
The left looks like the one on my 1978 CB550K.  I would guess that the right side is a non US CB550 control if it has the light switch.  Ebay has a far reach and I've done this mod for my CB900F.  Are you from the US?
Dan
Offline Taylor
« Reply #12 on: May 16, 2010, 08:25:44 AM »
Yup, living in Minnesota actually.
Offline gane
  • Gane
« Reply #13 on: May 16, 2010, 07:40:02 PM »
Gents, Excuse please, It's been many years...But, I dimly recall that at one time, fused power for h/l went thru ign sw via br/w wire 1st thru r/h sw, & changed color Bk I think, back to harness, & then to l/h switch providing source for Hi/lo... later models recieved power directly to l/h switch within harness, bypassing r/h switch. if intested enough, you could probly re-trace wiring & restore on/off function by a simple re-connection at harness. luck G
Offline bender01
« Reply #14 on: May 16, 2010, 09:12:49 PM »
I also think 1975 was the last year the USA allowed bikes not to run without the headlamp on. So 76 and later did not allow the r/h switch to turn on and off. My 75 550k has the on /off option r/h switch. Hi/lo is on the l/h switch.
75 550 K1
74 750 K4
1968 450 K1 Super Sport
74 750k 836 project
Good luck!
Two Tired Quote !
