Author Topic: CB400F carb bowl o-ring size?  (Read 982 times)
HondaCB400F
« on: May 14, 2010, 07:16:55 AM »
I found the o-ring sizes for the internal stuff, but not the carb bowl and it's sure to leak if I don't replace it.  My industrial supplier should be able to get everything if I can find the sizes.  Anybody know it?
If I can get this guy to supply everything, I'll post his contact info.  Carb kit prices are simply rediculous and I'm not a "thrifty" kind of person at all.
Thanks,
Craig
Offline bradengineer
Re: CB400F carb bowl o-ring size?
« Reply #1 on: May 14, 2010, 07:46:51 AM »
try these guys, they're really helpful and if you order from them it almost always comes in 1 to 2 days.
1-315-926-5054 (direct)
1-315-926-5841 (fax)
customerservice@z1enterprises.com
Offline bender01
« Reply #2 on: May 14, 2010, 09:21:15 PM »
Kevin Hunter
E-mail Address(es):
  kthunter01@sbcglobal.net
This guy is a member. He sells a kit for all 4 carbs. Very reasonable. Every o-ring you need even if you dont need it. I dont know why he doesnt sell them on e-bay?  He sells the Phenolic brake pistons there. E mail him and save ALOT of $ and hassles. Make sure to tell him your year and model of course. If this info that Ive given you is bunk please post that as a reply! I have posted this info before. I will send him one now as i Have a friend that has been bitten by a SOHC 77 750f. Just this morning in RI.
75 550 K1
74 750 K4
1968 450 K1 Super Sport
74 750k 836 project
Good luck!
Two Tired Quote !
Offline Kevin400F
« Reply #3 on: May 15, 2010, 04:26:11 AM »
I use bulk 2mm cord, laid in the groove of a spare bowl converted to a cutting fixture, to get an exact fit then join the ends with cyanoacrylate.
If buying a stock metric ring size, I think you'll get your best fit with 2mm cross section x 63mm ID.
Kevin
