Author Topic: gear shift drum?  (Read 755 times)
Offline Zig
gear shift drum?
« on: May 14, 2010, 11:48:25 AM »
Hay all.
5 (indexing??) pins on end of shifter drum are not square to drum. Will this create a problem??
tia, zig.
« Last Edit: May 14, 2010, 01:55:12 PM by Zig »
Offline KRONUS0100
  • MAD MATT THE MANIAC
Re: gear shift drum?
« Reply #1 on: May 14, 2010, 11:55:31 AM »
ummmm..they look twisted.  might cause harsh shifting or hanging up in gear
MATT
Offline Zig
« Reply #2 on: May 14, 2010, 11:58:42 AM »
is some other evidence po was hard on gearbox, will check on cost for a replacement.
Offline mystic_1
  • 1970 CB750K
« Reply #3 on: May 14, 2010, 06:21:57 PM »
Wow, never seen that before.
You should be able to score a shift drum fairly cheaply.  Make sure you get the same style as you have now, earlier ones had different arrangement of plates on the end and correspondingly different detent arms.
mystic_1
- John Augustus Shedd
« Reply #4 on: May 14, 2010, 06:49:17 PM »
Could it have been incorrectly assembled?
« Reply #5 on: May 14, 2010, 06:51:20 PM »
Is the screw loose?
Offline mystic_1
  • 1970 CB750K
« Reply #6 on: May 14, 2010, 06:52:31 PM »
The pins sit down in holes that are drilled into the end of the shift drum.  In order to be deflected that much, the pins are bent or the holes are trashed.
mystic_1
Edit to add:  On the drum I just measured, four of the holes are 5mm deep, and the fifth is 9mm deep.
mystic_1
« Last Edit: May 14, 2010, 06:54:04 PM by mystic_1 »
