Author Topic: Belly pan for a 550  (Read 2364 times)
Offline fastbroshi
  • Puppet
Belly pan for a 550
« on: May 15, 2010, 03:01:03 AM »
  Anyone using a bellypan on their 500/550?  I need one that can hold 5 quarts.
Just call me Timmaaaaay!!!
Offline CBJoe
Re: Belly pan for a 550
« Reply #1 on: May 15, 2010, 03:24:04 AM »
'07 Bonneville Black
'65 CB77
'66 CM91 (C90'ish)
Offline turboguzzi
« Reply #2 on: May 15, 2010, 05:03:22 AM »
Here you go...
http://forums.sohc4.net/index.php?topic=66810.0
Joe
Joe, by bellypan i think he means an under the engine tray as this usually required by racing orgs to catch oil. Right broshi?
I been using one off a racing Honda 599, another good candidate could be the one that is used for the Triumph Thruxton for the Thruxton cup series. Havent checked it though.
Need to replace mine as its a bit cracked, will tel you if I come across something.
BTW, the main issue I find with all of them is fit around the ex pipe. dont buy one untill you decided which pipe you use.
TG
Offline fastbroshi
  • Puppet
« Reply #3 on: May 15, 2010, 12:58:54 PM »
Exactly. Thanks to the both of you.
Offline CBJoe
« Reply #4 on: May 15, 2010, 04:42:58 PM »
Here you go...
Joe
TG
Huh... learn something new everyday.  I never knew those served a purpose other than aerodynamics/looks etc.   I saw the reference to 5 quarts, so I though Sump.
Joe
'65 CB77
'66 CM91 (C90'ish)
Offline turboguzzi
« Reply #5 on: May 17, 2010, 02:50:10 AM »
Here you go...
Joe
TG
Joe
Joe, if you do come across a 5 quart sump for a 550 let us know, would be lovely ;)
tg
