Author Topic: Which Spec to Use for Valve Lash?  (Read 1029 times)
Offline psykod
« on: May 15, 2010, 07:07:48 PM »
I recently put in a Webcam 58a camshaft into my cb550.  I just realized that the Valve lash spec from Webcam is .004 inch for both intake and exhaust.  I set mine to factory specs of .002 intake and .003 exhaust.
I suppose I know that I should use the Webcam spec, but I was just curious as to why it's so different?
« Last Edit: May 15, 2010, 08:50:56 PM by psykod »
1977 CB550F.  Mostly Stock.
Re: Which Spec to Use for Valve Lash?
« Reply #1 on: May 15, 2010, 08:11:42 PM »
   I would just go with their specs, they are not a great difference from yours.
 I run a cam that uses .012  as opposed to 0.3 and .004 stock
Offline fastbroshi
  • Puppet
« Reply #2 on: May 15, 2010, 08:31:50 PM »
  Maybe their cam's metallurgy makes their cam expand a bit more?  That must be the case as I think their cams are just hardweld repops.
Just call me Timmaaaaay!!!
