Author Topic: So very mad at myself.  (Read 2544 times)
Offline Raul CB750K1
Re: So very mad at myself.
« Reply #25 on: February 03, 2006, 09:34:26 AM »
Skamania, if your sidestand doesn't stay retracted that probably means you didn't attach the springs were they are suppoused to. Post a picture if you can.
As a side note, I always thought that my CB750K1 was very near to vertical with the sidestand, so I bought a latter model spare sidestand (the one with the rubber), cut it shorter, welded, painted and reinstalled. It leant just a little bit  more. On the cons, it didn't stop on the muffler stop but against the muffler itself. The short way around would have been to shorten it even more, but I was afraid the chassis lug would not bear with the weight so I just reinstalled the original sidestand. In all my bikes, my routine is to retract the sidestand, put 1st gear and take off, so I've never started with the sidestand retracted. Probably it has to be with the fact that my first bike was a modern Suzuki wich will kill the engine if you put into gear with the sidestand retracted.
Raul
Offline skamania19
« Reply #26 on: February 03, 2006, 09:52:13 AM »
Raul,
  Seems like I did have to attach the spring in the wrong place because of the modified pipes. I'll take a closer look when it stops raining and I can pull the bike out again. Should only be a couple more months!
Columbia River Gorge: Where the wind blows and the rain sucks.
Jughead
« Reply #27 on: February 04, 2006, 10:39:54 PM »
Yeap that Happened to me once.It isn't Any Fun.Actually I fell off of the Side of My Bike.My Ass was Halfway on the Seat and My feet in the Air.Eventually My helmet Started Hitting the Ground and I could see the Rear Wheel Getting Closer. :o :o :o Being Upside Down I was Pinning the Throttle Wide Open and Couldn't Grab the Front Brake. :o :o :o About the Time I was getting ready to Ditch it and Take my Chances with the rear Wheel the Manager of Wal Mart came out and Unplugged the Damn Thing. ;D ;D ;D ;D
Sorry I just Couldn't Help it. ;) ;)
Howdy Fellers I haven't been here for a While.
