Author Topic: CB550 - question about assembling transmission  (Read 2338 times)
Offline HawaiiMike
    • Hawaii realtor
« on: May 16, 2010, 07:06:26 PM »
I'm putting my motor together and seem to have an issue with the transmission and how it engages the kickstarter shaft.  It appears that the top and bottom halves of the motor are going together correctly, along with the transmission shafts.  However, when I turn the transmission shafts with my hand, the counter shaft engages the kickstarter shaft and turns the gears, making a clicking sound.  I haven't figured out how to get it to "not" engage the kickstarter shaft.
Someone please enlighten me.  Take a look at the picture below.
Thanks, Mike
« Last Edit: May 16, 2010, 08:07:42 PM by HawaiiMike »
Offline svenD
Re: CB550 - question about assembling transmission
« Reply #1 on: May 16, 2010, 09:44:03 PM »
its supposed do that,otherwise the kicker wouldent work,no problem.
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #2 on: May 16, 2010, 10:38:16 PM »
there's a spring between the two halves of the ratchet that is supposed to push them apart when the shaft is not being turned. either it's missing or not effective.
if you look at your picture, the half that mates with 1st gear should be up against the case and not in contact with the other half when the kickstart lever is not depressed.
« Last Edit: May 16, 2010, 10:39:49 PM by paulages »
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Offline HawaiiMike
    • Hawaii realtor
« Reply #3 on: May 16, 2010, 11:22:01 PM »
Hi Paulages,
Thanks I will check it out.  I didn't remove the kickstart shaft when I disassembled the motor so I hope it just needs to be moved around a little.
Aloha, Mike
Offline paulages
  • 1976 cb735
« Reply #4 on: May 17, 2010, 09:43:55 AM »
Hi Paulages,
Aloha, Mike
i just had a cb350G in the shop with this problem, only there is no sump pan on those engines and the only solution is to split the cases.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline HawaiiMike
    • Hawaii realtor
« Reply #5 on: May 27, 2010, 01:18:39 AM »
Okay I figured it out.  Here's more info with pictures in case someone else has this problem.
http://hondacb550f.blogspot.com/2010/05/important-info-when-working-on-cb550.html
Offline paulages
  • 1976 cb735
« Reply #6 on: May 27, 2010, 12:16:12 PM »
i guess i assumed that the return spring was hooked up properly...  ::)  glad you got it figured out.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline cameron
« Reply #7 on: May 27, 2010, 12:36:18 PM »
Wasn't the problem exactly this?
1976 CB550F
Offline HawaiiMike
    • Hawaii realtor
« Reply #8 on: May 27, 2010, 12:53:24 PM »
The spring was fine.  It's just that the kickstart return spring was not attached to that little tang on the shaft (clutch side of the motor).
