Author Topic: does head tube angle= rake  (Read 1969 times)
Offline rippy154
« on: May 17, 2010, 07:22:25 AM »
   I was looking at a rigid frame that my friend has and he had the frame level on his bench and a magnetic angle gauge stuck to the head tube and it was reading around 45 degrees does that = the rake of the bike or give you a basic idea what the rake is?
Thanks
Re: does head tube angle= rake
« Reply #1 on: May 17, 2010, 07:32:11 AM »
Yes: "RAKE: The angle in degrees of the steering neck from the vertical cord."
http://www.performanceoiltechnology.com/rake_and_trail.htm
« Reply #2 on: May 17, 2010, 09:48:07 AM »
 That is a lot of rake.. are you sure frame is level?? Could be tough to ride or need raked trees.. If you want to change it..now is the time..
 Sometimes rake is listed the other way, ie 62 deg as opposed to 28.. but easy to figure out id that is the case.
Offline MaaseyRacer
    • Fuelist
1961 CB72
1961 CB77
1962 CB77
1962 CB77
1965 CB160
1970 Triumph Bonneville
1972 Honda CB450
1975 Norton Commando
« Reply #4 on: May 18, 2010, 12:52:10 AM »
Unless you are familiar with front end geometry and know what rake and trail are and do,  and understand it completely, there is now way in hell i would recommend using raked triple tree's, they are extremely dangerous when used in the wrong application and could quite easily lead to an out of control situation.
Offline MaaseyRacer
    • Fuelist
« Reply #5 on: May 25, 2010, 03:43:11 PM »
Don't tell the chopper guys this...
1961 CB72
1961 CB77
1962 CB77
1962 CB77
1965 CB160
1972 Honda CB450
« Reply #6 on: May 25, 2010, 03:59:19 PM »
It works differently in some cases with choppers, as i see it choppers are inherently dangerous any way.... ;D  Chopper rakes can be that extreme that raked clamps can be used to get the trail a little bit closer to something acceptable, although most people wouldn't know this.  I have a mate that had a Harley that he put raked trees on to lengthen the look of his bike and it rode like a pig, with the front wheel raised off the ground, you could turn the handle bars left through right and see the front geometry change, very dangerous.
« Reply #7 on: May 25, 2010, 08:04:08 PM »
I have a buddy that manufactures raked trees and other fork components, there definitely is a place for raked trees. Which does nir mean they are recommended in many other cases.
 There is OEM manufacterers that have produced raked trees for trikes (factory).. and I know of at least ine aftermarket trike builder that used them..
