Author Topic: voltage drop at Dyna-s ignition?  (Read 865 times)
Offline jessezm
  • '77 cb400f cafe build
  • Always wrenching...
« on: May 18, 2010, 07:25:55 AM »
A quick question--
  I've rewired my project bike (CB400f) with mostly new connectors, shorter runs, etc. and added a Dyna-S ignition and 5 Ohm coils.  The bike is not ready to run quite yet, but I was testing the circuits and noticed that I have 12.2 volts at the coils but when I plug in the power to the ignition it drops to 11.3 volts.  First question--is this in any way a significant amount to worry about or will it affect running?  Next question, would it be worth running the ignition relay modification?  I don't know if it would make a difference, since the dyna-s would still be drawing power from the same source and may continue to rob the voltage.  I suppose I could run the ignition's power wire to another source instead.  Does the voltage drop indicate anything at all being wrong with the ignition?  Last question--might this issue disappear once the bike is running, or does that make a difference?
I know this probably isn't a big deal, but I've got time before my tank and seat arrive and I'm looking for stuff to do...  Here's a link to my build thread:
http://forums.sohc4.net/index.php?topic=70938.0
Thanks!
Offline Gordon
  • 750K1, 550K2
Re: voltage drop at Dyna-s ignition?
« Reply #1 on: May 18, 2010, 09:23:40 AM »
Offline jessezm
« Reply #2 on: May 18, 2010, 09:38:56 AM »
Yep it does, thanks!  I was thinking it could be a voltage sag from the battery under load, but voltage at the battery when the ignition switch is on is still 12.3v.  I may try the relay tonight--it looks really simple and I have all the fixin's already.
