Author Topic: Bullet Size  (Read 2262 times)
Offline OldSchool_IsCool
  • Really feeling like an
Bullet Size
« on: May 18, 2010, 06:36:28 PM »
I searched but couldn't find the size of the bullet connectors on a stock wiring harness.  I found a site that sells bullets in 2 sizes.  0.156 in (approx 4.0 mm) and 0.180 in (approx 4.5 mm).  Will either of these sizes work?
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Re: Bullet Size
« Reply #1 on: May 18, 2010, 06:43:24 PM »
It's the smaller ones.
Re: Bullet Size
« Reply #2 on: May 18, 2010, 08:28:35 PM »
Thanks Scottly,
I found a battery for my digital caliper and measured a few.  It looks like the .180 (4.5mm) are standard US Auto Parts Store issue, the .156 (4.0mm) are available some places, but the REAL stock bullet connectors for 70's CBs are 0.136 (3.5mm).  I did find a few 4.0mm connectors on my bike.  They were connected to a silver box wired between the points and the coils.  Hmmm now WHO coulda done that?  :-X
I did find this site that claims 3.9mm are "Japanese Bullet Connectors"  http://www.eagleday.com/jaco.html  and here http://www.wiringproducts.com/contents/en-us/d100.html
Of course there is http://www.vintageconnections.com/mail_order_form.htm too
« Last Edit: May 18, 2010, 08:45:23 PM by OldSchool_IsCool »
Sure.
Is it hard?
Re: Bullet Size
« Reply #3 on: May 18, 2010, 08:34:17 PM »
Well, before I posted, I put a set of calipers on a stock K7 male bullet at the widest point, where it met the female, and read .150
Re: Bullet Size
« Reply #4 on: May 18, 2010, 08:49:18 PM »
Hmmmm OK.  I guess it's best to measure before you order!  Vintage Connections stipulates the 3.5mm are "70's Honda turn signal and current sport bikes".  So I'm guessing there may be a mix on our bikes??
Sure.
Is it hard?
Re: Bullet Size
« Reply #5 on: May 18, 2010, 08:57:56 PM »
Could well be a mix, but I always thought they were the same size. I would tend to believe the source that said 3.9 mm. It was not a turn connector I measured, BTW.
Re: Bullet Size
« Reply #6 on: May 18, 2010, 09:09:45 PM »
Agreed.  I think I'll get a quantity of 3.9 male & female, maybe a few dual and triple females too.I could always squeeze th3 3.9 sockets down a bit when working with turn signals.
Sure.
Is it hard?
