Author Topic: Weeping Fork Seal  (Read 1519 times)
Offline switchum
    • Studio Switchum facebook page
Weeping Fork Seal
« on: May 20, 2010, 02:32:50 PM »
"Weeping fork seal? Pry back the dust cover, and insert a strip of 35mm film between the male fork tube and the fork seal. Work around the whole seal with a "sawing" motion. The sprocket holes in the film trap grit that might be causing your leak. Takes 2 minutes, and is way easier than a fork seal replacement."
  Found this on Bike Bandit facebook page. There was a talk about "who the heck still use 35mm film", though...
Offline PxTx
  • See sig for possible trade?
  • Subs of Philly
Re: Weeping Fork Seal
« Reply #1 on: May 20, 2010, 02:51:15 PM »
Does Does this really work?  I've never had a fork seal fail on the non-brake leg of a n old Honda.  I always assumed the leaky seal was a result of a the seal loosing it's shape for the deflection and load from braking.  Is it even dirt that causes the leak?  I would think it wasn't but I would love to learn a new trick that works.
Offline rufusswan
« Reply #2 on: May 20, 2010, 04:33:51 PM »
Ain't no difference between a fork seal and a float valve.  Can be worn out, can have crap in it.
1971 BMW R75/5  2002 Bajaj Chetak
CMS-Japanese Motorcycle Supply Parts
