Author Topic: DAvid Silver Spares throttle cables  (Read 984 times)
Offline mycb750k6
  • "res ipsa loquitur"
  • Rocketman
    • photobucket albums
« on: May 20, 2010, 05:45:29 PM »
Ordered a set of throttle cables from DS spares for my CB750 K1.  They arrived three inches too short. DS said - Oh that was the UK version and sent me a set with the correct length - same part number. UK length is shorter? Are the bikes smaller too? ???
Do you have to specify - this is for the US or UK? I don't think so.
Offline david 750f
  • 1976 CB750F
Re: DAvid Silver Spares throttle cables
« Reply #1 on: May 20, 2010, 05:57:09 PM »
Just a guess but the non-US bikes may have come with a lower bar or lower bar option. The part numbers are definitely different for the UK vs. US throttle cables.
1976 CB 750F
Offline MickeyX
« Reply #2 on: May 20, 2010, 06:02:12 PM »
Hush just went through this very thing with them. He ordered a clutch cable specific for his NZ version CB650 and it was the wrong length due to his police bike having higher bars than the NZ version of bike normally on the road around there. He talked to them on the phone and everything... it is better to call them I guess and verify the length and the handlebar setup.
http://forums.sohc4.net/index.php?topic=69155.0
Offline petercb750
« Reply #3 on: May 20, 2010, 06:44:03 PM »
I've just fitted a set from DSS to my Oz K2 and had no probs, they are spot on - but then I do have the slightly lower "continental" bars on it rather than the standards that turned me into a windsock. ::)
1972 750/4 K2 (his), 1976 400/4 (hers)
1982 CB1100RC (ours)
« Reply #4 on: May 20, 2010, 10:08:04 PM »
Most US bikes have higher bars and need longer cables
Offline swellguy
  • An electric cattle prod is a
  • Divorce is so expensive because it's worth it.
    • http://ksphotos.com
« Reply #5 on: May 20, 2010, 10:24:01 PM »
When you say "they" do you mean push and pull? If so, I'll take them if you don't want them.
This project started in confusion and will end in disarray.
http://forums.sohc4.net/index.php?topic=76471.msg852227#msg852227
