Author Topic: Installing Shocks on my CB550  (Read 1939 times)
Offline gravano
« on: May 22, 2010, 06:17:50 PM »
Just bought these aftermarket shocks but am not sure how to install them.
No instructions came with em. Anyone have any experience?
http://cgi.ebay.com/ebaymotors/Honda-CB550F-CB550-CHROME-Custom-Classic-Vintage-Shocks-/370382229704?cmd=ViewItem&pt=Motorcycles_Parts_Accessories&hash=item563c8050c8
Thanks
« Last Edit: May 22, 2010, 08:29:21 PM by gravano »
Offline shizzomynizzo
  • It's 5 o'clock somewhere
Re: Installing Shocks on my CB550
« Reply #1 on: May 22, 2010, 09:41:59 PM »
Replacing shocks is a simple process. Put the bike on the center stand so the shocks are not compressed, and the rear tire is slightly off the ground. Remove the nuts that hold them on at the top, I believe they also attach to the grab bar. remove the nuts/bolts at the bottom. Then you just pull them off. Put the new bushings in the new shocks, reinstall them in reverse order.
Good luck!
1974 CB550
1985 XLX Last of the IH
2001 Street Glide
Offline gravano
« Reply #2 on: May 23, 2010, 06:01:41 AM »
Thanks.
Offline gravano
« Reply #3 on: May 23, 2010, 12:25:24 PM »
The only stupid mistake I made was putting the wrong bushing (too narrow) on and having to push like hell to get it out.
Offline Frostyboy
  • Retired: Never was an
  • Circa 1951
« Reply #4 on: May 23, 2010, 05:31:28 PM »
They look the same as a set I got from CRC2 online. I was a bit disappointed. I'm going to have to shim both sides of the top mount because they're not wide enough for the top pin. The clevis on the bottom is also wider than the bush in the swing arm, so I'm going to have to shim those as well. The bottom bolt is now to short as well, so longer bolts are in order. Will probably have to get longer bolts & cut to length because the increase isn't much.
Last year I joined a support group for procrastinators.
We haven't met yet.
[CB550F1]
Offline gravano
« Reply #5 on: May 23, 2010, 10:17:35 PM »
Yeah, I shoulda mentioned that. I needed longer bolts. You can go from 30mm to 35mm and be ok. I got a 40mm on the pipe side.
And, now that you mention I think I better get some shims for along the bottom. Thanks.
« Last Edit: May 24, 2010, 07:20:35 AM by gravano »
