Author Topic: Engine Install How to - with pics  (Read 28809 times)
Offline Bill K
  • 78 750k
« on: May 23, 2010, 08:17:24 AM »
  I searched and did not see this method used before. If it has oh well, my bad. This worked well for me. I installed my fresh 836 with no help, in about a hour.
   What you will need:  a length of pipe about 5 ft. strong enough to hold motor
                               3  tie down straps
                               2 Jack stands, and 2 milk crates if your stands are to short
                               some old towels to protect your engine
  My original plan was to get the motor up hanging on the pipe then slide it over into the frame. As it turned out once I had the motor up that wasn't happening. So with the bike on the center stand I simply "scooted" the bike to the motor. I'm not great at explaining things step by step so here are some pics.
« Last Edit: May 23, 2010, 08:50:09 AM by Bill K »
co425
Re: Engine Install How to - with pics
« Reply #1 on: May 23, 2010, 09:35:01 AM »
Pretty slick. Was trying to think of a way to do that last week with a cherry picker. I ended up wraping the crap out of the frame and the top end of the motor. I used a motorcycle jack to get it to frame height and two of us one on each side of the bike walked it in inch by inch until it droped in. My favorite way by far is just a completly bare frame with the engine on its side.
Offline zzpete
  • You better get an
  • 1969 CB750, 1971 CB750
« Reply #2 on: May 23, 2010, 10:26:13 AM »
I might try it. I have a motor to put in and last time I used the lay it on the side method which works all right. Thanks for the tip.  ;D
« Last Edit: May 24, 2010, 06:55:48 PM by zzpete »
"One of the things that make motorcycling so great because it never fails to give you a feeling of freedom and adventure." - Steve McQueen
« Reply #3 on: May 23, 2010, 07:12:53 PM »
That is very creative.
Offline CycleRanger
  • No comment about being an
« Reply #4 on: May 23, 2010, 07:42:52 PM »
Milk crates. Essential items for any shop!
I might try something like this myself when the time comes.
Offline Bill K
  • 78 750k
« Reply #5 on: May 24, 2010, 05:00:11 PM »
 Milk crates are essential for any shop. I use them all the time, very versatile. Just make sure they are the "heavy duty" ones before you trust them with alot of weight.  ;D
Offline gnarlycharlie4u
  • Far from being an
« Reply #6 on: June 03, 2010, 09:01:13 AM »
wow kudos for working smart, not hard.
it looks like you scooted the milk crates rather than just the motor though.
Offline wannabridin
  • Patience made me a
  • -Garrett
« Reply #7 on: June 03, 2010, 09:37:57 AM »
very nicely done!!  i've been contemplating laying my motor on its side like is the norm around here, and it seems good enough, but make sure theres PLENTY of padding!!  this is a great, and most importantly CHEAP, method of installing the motor!  KUDOS my friend!
Offline sangyo soichiro
  • Tuck
  • ☢ the atomic playboy ☠
« Reply #8 on: June 03, 2010, 10:54:21 AM »
That is genius!
1974 CB 750
1971 CL 350 Scrambler
1966 Black Bomber
Too many others to name…
buckeye74
« Reply #9 on: June 05, 2010, 07:47:52 PM »
Any pics of when you lay the motor on its side?
Offline HedNut
  • Underwater Basket Weaving
« Reply #10 on: June 10, 2010, 11:20:58 AM »
NICE! Slick idea man! Cheers!
traveler
« Reply #11 on: June 10, 2010, 11:47:04 AM »
best part is you were able to do it by yourself, and only took one hour!
You could do the reverse to pull an engine quickly as well.
Thanks for sharing!
~Joe
Offline HAIRHEAD
« Reply #12 on: June 11, 2010, 05:54:28 PM »
                               3  tie down straps
AWESOME....I love the off the map black arts
77 R100/7 cafe,75 CB550 caffeinated,74 CB450(520)TWIN, 73TX650,72 CB750,72 CB350 TWIN,75 XL100,
DocVile
« Reply #13 on: June 16, 2010, 07:17:38 AM »
This is great!!  Will be doing it this weekend!!
Offline cb650
« Reply #14 on: June 16, 2010, 03:44:11 PM »
Very cool!!!     Paul you seein this!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! ;D
redbullssg
« Reply #15 on: June 27, 2010, 10:34:03 AM »
This looks like a great method.  You could also use a motorcycle jack for the frame then just roll it over the motor.
At my work, they throw away bearing sliders and rails away that aren't all bad all of the time.  If they get a little warn, they get tossed and replace, but would be great for something like this.  The rails are either of two sizes, 1" or 1-3/4".  I think the 1" would be strong enough.  Then all I would have to do is mount some short hooks on both sides of the sliders where the straps would go, and you could just slide it in on the rail.  And instead of using jack stands to suspend both ends, I could use my beam in the garage.  When I built the garage, I was sure to put a overly large support beam in to hoist motors, snomobiles, what ever.....  Great idea Bill!
Offline torrinh
  • If you don't ride in the rain, you don't ride.
« Reply #16 on: June 30, 2010, 07:34:15 AM »
you could put locking casters under the milk crates then just slide the whole rig sideways so the engine goes into the frame. Great idea though, better than my dad and I busting our knuckles to get that b*tch in.
1983 Kawasaki GPZ 750
1978 Honda CB750K w/ 1976 CB750F1 motor
1979 Suzuki GS550L
Offline vargas
« Reply #17 on: July 02, 2010, 02:02:41 PM »
Great idea! this is how i will reinstall my engine.  moving the bike to the motor seems like a better idea than moving the motor to the bike.. you have to keep in mind that the motor is hanging from ratchet straps.. making it harder to control its motion while trying to place it in a small hole surrounded by fresh paint or powerder coating.
question where the heck do you guys get your milk crates?
THE DUDE
« Reply #18 on: July 02, 2010, 03:45:39 PM »
Very Clever but I just bend over and pick mine up and put it in    ::)
Offline CycleRanger
« Reply #19 on: September 26, 2010, 12:20:59 PM »
Behind the Safeway, late at night....  ;)
But seriously, many thanks to Bill K.
I just duplicated his setup and effortlessly installed my 750 engine in the frame by myself in about 10 minutes.
Offline sebatje
    • vsmotors
« Reply #20 on: October 11, 2010, 01:27:53 AM »
When I install an engine, I just get someone to hold the bolts, I lift up the engine in my arms and put it on its place in the frame. Mine is a 400 , are these 750 engines so heavy?
Offline The_Crippler
  • Work in progress.
« Reply #21 on: October 11, 2010, 06:06:27 AM »
The mountain to Muhammad and all that.
Another point for the uninitiated that might have been missed in the pic:  Notice in the first picture that the oil filter is on, and then not in the others.  This is very, very much key.  How do I know?  I missed that detail in engine removal pictures before I did it the first time a while back.  I fought with it for much longer than I'm willing to admit before I figured it out.  Once the filter was removed, *woosh* right into the frame.
Offline grumpy
  • ..... '73 750K3 .....
« Reply #22 on: October 21, 2010, 07:12:35 AM »
COOL!
... are these 750 engines so heavy?
Yeah!
They weigh about 5lbs more than I!
« Last Edit: October 21, 2010, 07:14:52 AM by grumpy »
Offline Flying J
« Reply #23 on: October 22, 2010, 01:17:00 PM »
I did the same thing to get the motor out of my 550, but i used rachet straps to the rafters and then just rolled the bike away. Works great.
Offline MoMo
  • Ride like you're invisible
« Reply #24 on: October 22, 2010, 03:37:26 PM »
Necessity is the mother of invention -compliments to you
