Author Topic: cl360 timing  (Read 2106 times)
Offline parm
cl360 timing
« on: May 23, 2010, 01:54:37 PM »
hi there i am having trouble timing my cl360,
1) i turn the engine until both points are open to there max and i gap them .013"
2)then i attach my test light and turn the engine utill the L cylinder is on its compression stroke, the light comes on just past the LT mark so i turn the plate and get it so the light comes on at the LF mark BUT as soon as i tighten it down the lights goes out?! i am very confused, the plate doesnt seem to shift. so ill turn the motor all the way around till the L cylinder is on its compression stroke, and the light goes on but again just past the LT mark. what am i doing wrong?
Offline kirkn
Re: cl360 timing
« Reply #1 on: May 23, 2010, 02:51:11 PM »
Here's a link over to the HondaTwins forum, where the exact timing procedure is posted as a sticky.  It's the bees knees...
http://www.hondatwins.net/forum/viewtopic.php?f=18&t=883
Offline parm
Re: cl360 timing
« Reply #2 on: May 23, 2010, 03:56:24 PM »
i should have mentioned that was the procedure i was using, not working, every time i tighten down the plate it goes back to turn on just after LT even if i compensate for it.
Offline tbpmusic
Re: cl360 timing
« Reply #3 on: May 23, 2010, 04:37:41 PM »
It's very common for them to move a bit when you tighten the screws.
All you can do is pre-compensate a little bit.....
Bill Lane
Offline parm
Re: cl360 timing
« Reply #4 on: May 23, 2010, 07:41:35 PM »
pre compensated but just goes back to the LT mark,
Offline tbpmusic
Re: cl360 timing
« Reply #5 on: May 25, 2010, 09:23:06 AM »
Then compensate some more until you get it.....
Then go here and read how to do it - it's not like an SOHC Four or anything.....the right side point gap situation is counter-intuitive........
Bill Lane
Offline parm
Re: cl360 timing
« Reply #6 on: May 25, 2010, 06:42:01 PM »
GOT IT! thanks alot, i changed my point gap to .014 and i was able to compensate to the mark easier. now onto my next issue. everytime i kick the kickstarter it feels like for 3 or 4 attempts it just rolls over, and then finally it will kick, so it ends up taking me like 30-40 kicks when its cold. the motor the in the cl360 is a cj360 motor cause i blew the other motor. has anybody ever heard of an issue like this?
