Don't know about the tubing bender stuff, but in regards to you wanting to knurl tubing......
Tubing isn't easy unless it's really thick wall. Do you have any knurling tools for the lathe? If you do, try practicing on some scrap first. Use a COLLET if you can in place of a 3-jaw chuck, it's more solid. Turn the O.D. to get it concentric first, keeping in mind that the O.D. will expand after knurling by as much as .020 to .030. Knurling, (if you're using the "bump type" tool) requires LOTS of cross slide pressure to get satisfactory results without "double tracking" the knurl. That means that you have to have the knurl tool points tracking back into the same groove previously made on each revolution. If you're using the two-roller knurl tool, turn the tool just slightly to the right so the leading edge of the rollers are contactacting the work (2 degrees is about all you need). With the spindle off, and in backgear (low speed), crank in the knurls very hard without bending the work. Jog the spindle until you get at least two turns, and check that you have single tracks from each knurl roller. If you do, great. If not, back the tool off and manually place the knurl points in a known good groove and try it again. Don't forget to keep it well oiled, and manually feed the tool towared the headstock to the desired knurled length. Keep the tool really tight in the compound, the compound cranked in until it bottoms out, and the stock as short as possible. Remember, rigidity of all things are required to get good results. There are also "balanced" knurling tools available that have 3 rollers, but are very expensive and were designed for screw machines. There are also hand knurling tools, but don't do a very good job. Good luck with your projects.
Steve F
