Hi,
I saw a few posts that discussed this, but there was not much about cleaning clogged brake lines; most of the advice was to replace. Well I am on a tight budget and $33.00 per line is steep. I don't want to go SS braided at this time either.
So, has anyone cleaned their clogged lines? Any ideas? I got the lower line clear because I was able to jam a coat hanger into it, but the upper line is different as you cannot directly access the hole. I've tried tons of brake parts cleaner and jamming various things into the line, but cannot get anything solid in there because the holes are inside of the ring that allows the 90* connections at the master cylinder and the brake light pressure switch.
Any thoughts on boiling?
Thanks for any help.
